65 BJ8 with overdrive. Have oil dripping off the X channel of the frame to the right of the gearbox stabilizer. It is a significant leak drip....drip....drip after a 30 min drive. Lost nearly 2 qts in probably a couple tanks of gas. Can't for the life of me tell where it is coming from.
Oil appears to be on top of frame. Of course it could be blowing there. Is there anything prone leaking in this area? The only things I can see above the area are the speedometer drive and the overdrive lever. They may have a drop but nothing obvious. The propeller shaft flange seems oil free so I'm thinking the transmission seal is okay. Overdrive to transmission seal doesn't show oil.
Tightened overdrive filter brass nut. I know these can leak. Drain plug looks dry. Bell housing looks dry. Of course the drip stops shortly after the car stops. I'll check the newspapers in a day hoping. Could the speedo gearbox or overdrive lever leak that much? Is there any kind of pressure relief thing.
For this much oil to come out it has to be under pressure or leaking from a low point in the gearbox.
