New Old Bulb Holders
hondo402000
well I am on my way to making up my new old bulb holders, I have 2 finished, one is the alternator warning lamp and the second is the Hazard warning lamp.
And thanks to Erik at Hermajestys auto shop in RI, he found some original bulb holders from old harnesses and is sending me 5 more. Also a forum member in AZ is sending me some too, so with both I should wind up with all the correct wiring colors. I can then make pigtails, using the correct color wire and then crimp the replacements in place, and then use heat shrink tubing over the crimp and I will retape the harness. I also purchased a rebuild alternator, the bosch unit, I think part of my problem was an alternator issue too
Hondo
Brosky
"I love it when a plan comes together"
stolen from the "A Team"
hondo402000
hondo402000
All the bulb sockets have their pigtails made up. Crimped and soldered, next is to cut the old ones, crimp in the new ones, solder them and heat shrink to cover then retape the new alternator wire to the alternator, check for any other wires that might have melted the insulation, hopefully done this weekend, When it warms up
DNK
Keith - Ran all my bulb light wire to this.A little late for you prolly. But it kind of keeps all the wires separated
hondo402000
hondo402000
yes its too late for that but thats not the issue now, I did get all the bulb sockets replaced, the wiring harness tape off, pulled out the burned Brown Yellow wire from the IGN warning lamp. ran the new wire and taped up the harness from the alternator to the fire wall. now the questions. I am a tad bid cofusesed as to which sockets get which bulbs, the two red warning lamps, the one on the left is suppose to be the hazard warning lamp and the one on the right is the brake failure warning lamp and the third in question is the low oil pressure lamp. I was under the impression that the 2 red warning lamps were suppose to glow dimly when the Ign is turned on. but if the hazard lamp is suppose to be plugged in to the red lamp on the left, based on the wiring diagram there is no way that lamp can glow upon turning on the ign switch. Based on Dan masters book in order for the lamps to glow dimly you have to have 2 bulbs in the same circuit, which splits the voltage in half causing the lamps to glow dim. there is no other bulb in the hazard circuit. so If I plug the hazard bulb in the left red lamp, the PDWA bulb in the right and the low oil pressure into the Oil socket in the tach, when I turn on the IGN switch the right red bulb(PDWA) will glow dimly, the green lamp in tach gauge(oil) will glow dimly and both turn off when the car starts, and when I turn on the hazard switch the left red warning lamp will flash, Is this correct?
Hondo
hondo402000
hondo402000
Well Back in business, everything hooked back up no shorts. the new smoke installed. Now its back to the carburators, I even got my OD light I installed to come on when the OD is engauged
Hondo
DNK
Wasn't a correction for your problem. Just something I did.
When I got my car all those wires where soldered together and taped. Don't know if that was factory or not.
mallard
Glad you got it all back together. Had an early breakfast run today with the club so I was not able to check the locations of the wires. Again it's good to hear that the smoke did not come out of the wires.
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
K TR2/3/3A Old school penetrating oil? Triumph 24
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
R Old History - List of USA TVR Authorized Dealers TVR 10
Popeye General TR Old robbins top in box Triumph 7
dougie Pistons - Old vs New Austin Healey 12
B Help for Old Men Restoration & Tools 15
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
roscoe New / old hard top Austin Healey 16
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Removing Old Radio Austin Healey 4
Bob Claffie New old car Other Cars 7
Mark Bailey Old tire rule? Restoration & Tools 5
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
DrEntropy Looking thru old pix Other Cars 8
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
R How old is "dead" FORUM Navigation Questions 5
D General Tech Old gasoline disposal Triumph 17
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
tinman58 General Tech Why I love old cars Triumph 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
B TR6 New [Old] Member Triumph 2
M Old English White Paint Code for early BE Spridgets 1
E Trying to ID some old classic car gauges Restoration & Tools 2
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
AngliaGT Cool Old Truck + Spotted 1
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
jfarris "Old Yeller II" Spotted 3
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
AngliaGT My Old Ford Consul Capri Other Cars 0
Answerman Restoration of OLD [pre WWII style] leather seats Restoration & Tools 5
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
doc50 New old member. Spridgets 43
doc50 New Old Member...sort of. Spridgets 7
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
S TR2/3/3A On those old original coils Triumph 2
D never throw old parts away.... Austin Healey 7
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
JimLaney Liquids for 50 + year old Sprite Spridgets 5
