Years ago I cleaned and coated the inside of my gas tank using TRF's slushing compound. The car went back to storage had a couple of gallons of fuel in it. Can't even blame the DPO. Now I have cleared out the gas residue using muriatic acid. Found areas of slushing compound sealer had failed and was peeling away from the tank. I was able to clean it out using Dupont paint thinner.
There is limited surface rust on the inside. Any recommendations on what to do now to protect? Have seen mixed comments in other places about sealers (Kreem) that I suspect were like TRF's slushing compound. Has anyone tried POR tank coating?
