    Do you enjoy BCF? Is our forum a useful resource? Do you want to ensure we can stay online?
    Please consider supporting us by **Upgrading**
TR4/4A Tr4 Vented gas tank banjo bolt
Dash
I'm currently under way on a body off restoration of my '63 TR4 and every nut and bolt has been removed so far with the sxception of one. The gas tank is original to the car and it's vented. The vent pipe needs replacing but the banjo bolt has snapped..partly due to the fact that's it's hollow I guess and can't handle much torque but I see that there is no car specific banjo bolt available for the 4 and the thought occurred to me maybe because it's soldered in and not threaded. I do see a fine bead of solder around the base of the washer..I can't imagine it not being threaded but then stranger things happen to me all the time so I don't panic over surprises..Anyway, before I start drilling with the hopes of retapping, has anyone had one of those bolts out on your TR4 vented tank?
I've had this car for 40 years and a lot of stuff I can work my way around blindfoled but I'm never afraid to ask stupid questions.
I'm new to this forum so I'm sure I will prove that out as I try to get this thing back together..Ha
Thanks
TexasKnucklehead
There are no stupid questions. Welcome to where some can answer a stupid question with a smart (***) answer.
I think the TR4 tank is similar to the TR3 tank. In any event, I have a TR4 cap on my TR3, but I drilled a small hole in it to allow the cap to vent -and I plugged that vent pipe from the top of the tank. I think you can search this forum and find many others who have had issues with hard cornering and gas flowing out that vent. This forum has proven to me that there is often more than one solution to any problem.
I hope you find your TR4 and this group enjoyable.
SKM
I have an original vent tube and banjo bolt from my '62 TR3B I'd sell. I installed a stainless steel tank and set up the vent differently. If interested, send me your email address and send you photos.
Dash
Stubborn bolts can be a real nightmare but this one is getting ridiculous..I've used a left handed bit and extractor with no luck and currently using regular bits in increments to slowly eat away at it. I think the solder around the bottom washer seeped under to contact the bolt and has a heck of a grab on the thing. In any case I will probably end up bypassing it using an alternative venting system but in the meantime it's one of those things that after you've spent x amount of time on solving it becomes personal, you know what I mean?! Having said that, if by chance I finally succeed though I would like the option of using it but before I get carried away on the drilling can you tell me what size the bolt you have is..a 7/16 with a thread count of 20..24?
Thanks
Dash
7/16 is the top of the bolt that sits in the eye I think..the threaded bottom is obviously larger and so far as close as I can tell it's something maybe closer to 5/8?..but I can't tell the thread count..
Any banjo bolt would do I suppose but to drill out a hole to tap for a generic bolt,,well not sure how much material there to work with..
Dash
Thanks to all who tried to help but I have solved the mystery.. Why I didn't think of this sooner..gee whiz! I was able to extract the banjo bolt from an exact duplicate tank I took out of a parts car many many years ago..thought I threw that thing away but anyway I discovered the bolt is 1/2-20. So I have been indeed dealing with one that is not original to the tank..It's bigger and was soldered in which was the cause of all the aggravation. Don't know why that was done unless the previous owner was concerned about leakage on hard corners everyone talks about and thought it to be a cure..dunno..
Anyway, I'm thinking a relatively quick and easy fix, although a ridiculous overkill, is to insert a helicoil giving me the option to either use the existing vent or make for an easy cap off...
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
M For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 3
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
Twit TR4/4A restoring TR4 sun visors Triumph 0
glemon TR4/4A Wheeler Dealers TR4 Triumph 8
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
Rut TR4/4A TR4 in Longmont, CO Triumph 2
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
Twit TR4/4A TR4 trunk badge Triumph 8
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe Wanted Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 1
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
C TR4/4A TR4 Thoughts Triumph 15
Rut TR4/4A TR4 wood dash Triumph 26
O TR4/4A TR4 Dove Triumph 4
T For Sale TR4 / 4A Parts Lot [or lots of parts...!] Triumph Classifieds 0
S For Sale Triumph TR4 Factory Parts and Service Manuals on CD/ROM - 1961 - 1965 Triumph Classifieds 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
ckeithjordan TR4/4A TR4 Carpet Comparison Triumph 7
M TR4/4A Do MGF seats fit in TR4 Triumph 0
