catfood
I'm about to replace some of the hacked together fuel lines on my BN1. First bit I'm replacing is the pipe and banjo assemby that goes between the two carbs and down. The item I'm replacing has a 2 inch down pipe (which I'm sure is wrong) and my replacement part has about a 12 inch downpipe. The issue I have is when I place it in position the down pipe hits the engine mounting bracket so I obviously need to bend it a little. The question is should it pass forward of the engine mount bracket or aft (or even through the hole in the engine mount bracket)?
After that where should the fuel pipe go? Curently it passes under the car which strikes me as a little dangerous given the Healey's ground clearance. Should it pass through the transmission tunnel?
Cheers
Steve
Cheers
Steve
