static timing with electronic ignition?
tr6lover
hey guys, i have a crane xr700 and was wondering if you can do a static timing with electronic ignition (engine not running) thanks
Randy
TR3driver
Great Pumpkin - R.I.P
Yes, it can be done, but the procedure varies depending on whether you have an early or late module. The procedure on page 13 of the instructions is basically static timing.
T
tr6lover
hi randall, i have an early one i think because the late ones had a led light correct? this was installed on my car whe i bought it and do not have the instruction booklet that came with it......
Randy
70herald
Randy
Why static? is the engine not running at all, no timing light? Anyway, with and earlier type of XR700 the problem is going to be figuring out exactly when it triggers. What I did (this morning!) to set up the XR700 was turn the crank until cyl 1 was aprox 9 degree before TDC. Now move the optical trigger / distributor etc until the spark fires. You could hook up a spark plug directly to the coil but be very careful. The spark will fire at the beginning of the slit, so make sure you are aiming for the correct side of the slit. That extra LED on the newer units made this really simple, however for some reason, I still don't have a spark at all, and the XR700 IS firing.
Adrio
I have been curious about how this is done. I use points on both my cars but a friend has come by and asked me to time is new (to him) TR3 that had one of these in it. I am sure this is not the last time some one will need to know how this is done.
BTW, I keep an extra plug wire and plug just for this sor to of thing. It come in handy more often then you would imagine. My suggestion is next time you change your ignition wires and plugs, keep the best one of each. Even for the caps that have the wire screwed in I just use the output of the coil for my tests.
TR3driver
Randy
Poke around on Crane's website, it should still be there somewhere. Or PM me your email addy, & I'll send it to you.
Basically, for the non-LED version, they tell you to hook up the coil with the center wire laying on the rocker cover, and watch for a spark. I believe you could also use a test lamp on the low tension terminals, but haven't tried it myself.
70herald
The low voltage side gets a pulse of several hundred volts, with a low current. You can't just hook it up to a 12 volt test lamp.
TR3driver
No, that would be the XR3000, which is a CD type unit. The XR700 is still Kettering style.
70herald
According to the Crane web site both the 700 and 3000 are inductive systems, the difference is in the spark gap (current) and spark duration. "low voltage" is ~400 for either system. BTW, the low voltage on a standard points system hits about 250 volts when the points suddenly disconnect.
Part Number: 700-0231 BACK TO LIST
Primary Voltage Output 400 volts (inductive discharge)
Primary Energy Output 60 millijoules with PS20/40 coil.
Peak Spark Gap 60 milliamps with PS20/40 coil.
Spark Duration 300 microseconds at 6,000 RPM
Part Number: 3000-0231 BACK TO LIST
Primary Energy Output 90 millijoules with PS91 coil.
Peak Spark Gap 100 milliamps with PS91 coil.
Spark Duration 2800 microseconds at 2,000 RPM
Dimension 5L x 3W x 1-1/2H, 1-1/2 lbs.
TR3driver
Interesting. It must have changed then, since the old XR700 was definitely just a switch to ground. It was "inductive discharge", but the ignition coil was the inductor.
And I have an old XR3000, which is definitely capacitive discharge.
70herald
Randy
Thinking about this a bit more, yes. hook up a voltmeter to the "GROUND" side of the coil and ground. When the XR700 sparks, the voltage will jump to 12 volts. When the coil is "charging" ie on what would be "dwell" if you had points, the voltage will be at 0.
A very simple explanation: when the coil is "charging" ie current is flowing, the ground side of the coil is connected to ground so the voltage difference between coil "ground" and ground is 0. When the spark occurs, the "ground" side is disconnected so there will be no current flow across the coil and no voltage loss so the voltage on the ground side will equal the input or 12 volts. A 12 volt light bulb would work just as well.
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
BN6_2197 BN6 Static Timing Austin Healey 2
J TR6 73 TR6 Static Timing Questions Triumph 6
C Static timing before engine start up Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
B Static timing Austin Healey 8
C Static Ignition Timing Austin Healey 1
af3683 TR2/3/3A Set Static Timing on TR3B - Car Runs Poorly Triumph 27
M Test light to set static timing Triumph 39
af3683 TR2/3/3A TR3B Static Timing Triumph 28
T 100M Static Timing Austin Healey 0
mrv8q TR2/3/3A TR3 Static timing; point of confusion. Triumph 16
MadRiver TR5/TR250 TR250 Static Timing Triumph 8
Tabcon Pertronix Static Timing? Triumph 15
H TR2/3/3A TR3A Timing [Static or Dynamic ?] Triumph 10
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
dklawson Spitfire Spitfire Static Timing, Conflicting Data? Triumph 9
jjbunn Static Timing: 12*BTDC or 8*BTDC ? Triumph 17
MTribe setting static timing with pertronix ignitor Triumph 0
MTribe how to adjust static timing? Triumph 8
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
Daimlerdb18 Timing light timing versus static test lamp MG 7
startech47 Static timing a 1979 Midget Spridgets 4
mrstinson Renew Dizzy and Static Timing Spridgets 15
P Static Timing Austin Healey 3
R Pertronix ignition and static timing MG 22
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
S Wanted MGB Static Seat/Shoulder Belts MG Classifieds 0
I How do you static time a 948? Spridgets 4
B Radio Static Austin Healey 4
Twosheds HSTRL Static Display Reopens Triumph 0
T How 2 remove "static" and white dust ? Restoration & Tools 8
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
