dklawson
I tried the search feature to see if this had been covered before but I didn't find what I was looking for.
My sons and I now have our project '72 Spitfire Mk4. As part of the basics I want to go over setting the points and static timing. I have Haynes, Bentley, and the factory documents on a Heritage CD. Prior to this all my LBCs have set the static timing between 5-8 BTDC. Haynes says this 1300 engine should use 6-8 BTDC, Bentley and the Factory owners manual say 6 ATDC. Under the bonnet, the factory tech sticker remains and it says to use a dynamic (idle) timing of 2 ATDC.
The distributor appears to have a vacuum retard unit without vacuum advance. Is Haynes wrong and are Bentley and the factory manual correct? Is the static timing set to after because of the retard only vacuum unit on the dizzy?
We're just getting started with this car and things like this are quite a bit different than on our GT6. All advice is welcome.
