Static timing before engine start up
chris57
Member
I read someplace that there is a light bulb check you can do with the distributer to confirm that the contacts are opening at the #1 and about 5 deg before TBC. Can anyone talk me through this? 1275 engine.
C
chris57
Member
Wow. Awsome Doug. Thank you. It now leads me to rethink positive vs negative ground. I believe my 64 sprite was originally positive to ground. And that is how I have it now. This car hasn't run in nearly 20 years. I don't know if previous owners switched it over to negative ground. I understand that it's not hard to do. Need to change polarity in the generator. I read that someplace as well.
Onward. Maybe I'll have the engine started this weekend.
dklawson
If you decide to swap polarity, there are a number of online articles and old threads here that can walk you through the process. Links to those can be posted when needed. In the meantime, let me know if I need to clarify anything in the PDF.
nomad
To static time I just find 8 degrees BTC on #1 and use a ice pick type continuity tester while I rotate the distributor. Don't even have to have the cap off...just use the coil post. If you are not sure whether you are on #1 you may have to remove the valve cover or you may be able to determine that through the oil fill by knowing the valve sequence. Not sure on that but I would bet its possible.
Kurt.
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
BN6_2197 BN6 Static Timing Austin Healey 2
J TR6 73 TR6 Static Timing Questions Triumph 6
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
B Static timing Austin Healey 8
C Static Ignition Timing Austin Healey 1
af3683 TR2/3/3A Set Static Timing on TR3B - Car Runs Poorly Triumph 27
M Test light to set static timing Triumph 39
af3683 TR2/3/3A TR3B Static Timing Triumph 28
T 100M Static Timing Austin Healey 0
mrv8q TR2/3/3A TR3 Static timing; point of confusion. Triumph 16
MadRiver TR5/TR250 TR250 Static Timing Triumph 8
Tabcon Pertronix Static Timing? Triumph 15
H TR2/3/3A TR3A Timing [Static or Dynamic ?] Triumph 10
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
dklawson Spitfire Spitfire Static Timing, Conflicting Data? Triumph 9
jjbunn Static Timing: 12*BTDC or 8*BTDC ? Triumph 17
MTribe setting static timing with pertronix ignitor Triumph 0
MTribe how to adjust static timing? Triumph 8
T static timing with electronic ignition? Triumph 10
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Daimlerdb18 Timing light timing versus static test lamp MG 7
startech47 Static timing a 1979 Midget Spridgets 4
mrstinson Renew Dizzy and Static Timing Spridgets 15
P Static Timing Austin Healey 3
R Pertronix ignition and static timing MG 22
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
S Wanted MGB Static Seat/Shoulder Belts MG Classifieds 0
I How do you static time a 948? Spridgets 4
B Radio Static Austin Healey 4
Twosheds HSTRL Static Display Reopens Triumph 0
T How 2 remove "static" and white dust ? Restoration & Tools 8
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
