Plastigauging for checking crankshaft clearences
I thought I would start a new thread on this subject rather than hijacking one of the existing threads. I know Jack is getting ready to do this, so I thought now would be a good time to go over this. Plastigauge is a decent way for the average DIY engine builder to check clearences, but if you don't have alot of experience with this product, much can go wrong to askew your readings.
Checking the mains is easier because the crankshaft has much less chance of moving, the rods are much harder to check because while torqueing and lossening the rod bolts it's real easy to move the crankshaft and if the the crankshaft moves then your palstigauge reading are useless. So the big thing with palstigauge is too make real sure that nothing moves during the process and great care is take when removing rod and main caps, doing it a couple of times is a good way to double check yourself. If the crankshaft moves while you're plastigauging, then it will smear and this will make you think you have less clearence than you really do have.
Jack if you didn't have your rod's big ends resized, then by all means atleast have a machine shop check them.
FWIW, I build all my street engines to .0015" on rods and mains.
Hap,
is that .0015 per side or total?
mark
jlaird
Boy am I glad Hap is back.
See my answer on another thread Hap.
Except that my engine guy was so jump on the problem and echoed what you all have been saying you almost got an engine to check.
Will be at Anderson track first weekend in Nov. and was just going to come by.
Hap Waldrop
.0015" will be what you see on the palstigauge or what you will looking for. Mark think of it this way, the diameter of crankshaft journal is for example .0015 than the housing bore of the rods or mains loaded with bearings, so that dimension is constant at 360 degrees.
You guys doing clearence can use this simple formula, if you have access to a bearing book, on paper you can do your math and spec to the machinist the clearence you want. Remember if extra clearence is desired (for racing for example) get it on the crankshaft journals, never work outside of the sepc of a rod or main housing bore this is what holds the bearing and should always be within factory specs.
Housing bore diameter - bearing shell thickness x 2 - crankshaft journal diameter = clearence.
Jack you coming up for a Legneds race, yes please look me up. Thanks again for the lead on the legends car buyer in Alabama, unfortunately I could never get the legends car owner to call me back, he's a busy guy. Anyway he called me me last weekend and told me to help sell it for him again, he was ready to get it out of his garage (too many toys) Anyway I put it on Ebay, reserve is $4K, so if any of your legends buddies need a cheap car, tell them to check out the Ebay ad.
jlaird
That seems like an excellent price. It just may go fast.
Yep will be in Anderson for the Legend races. Had in mind to biring my engine to you at that time but my guy down here knew all the answers with out the questions and told me exactly what I needed to do as did you all. So I just gave him the whole job.
Check mains and journals and make em right.
I expect that somehow I got the wrong size mains in her as I get no noise from the engine and would I think if rods were loose.
Anyway, he said he could get on it before the end of the week and would call as soon as he checked it out.
Hap Waldrop
Yes too much clearence will for sure result in lower oil pressure, so you may be on to something. The factory spec range on rods and mains clearence can easily get people into trouble, as most just take thier stuff to the machine shop and the machinist if not told a specfic spec will just end up in the spec range somewhere, but on our little cars, that could be as much as .002", which works great in a race car engine at 7000-8000 rpm, but not real good in a street car where such clearences can easily net low oil pressure, that's the main reason I blueprint every motor I build whether it's for the street or racing. When I take a block in for line boring or send a crank off to be ground undersized I spec the exact number in the spec range I want the job to end up at, so in the end I can control the amount of clearance I have. This is something that often times gets overlooked by DIYers, in many way we put too much trust in out machinist to make such decisions for us.
jlaird
You in Anderson Ben? If so PM me an address and a phone number so I can chat if time permits.
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
T General MG Checking tiers tread MG 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
K TR2/3/3A Checking steering box End Play? Triumph 5
B TR2/3/3A Checking oil in rear axle Triumph 2
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
E TR4/4A Checking a generator Triumph 12
5 Checking The Spedo Spridgets 11
PSJ Checking for interest - meeting of NW Organization of Spridget Handymen In Transit Spridgets 6
vette Checking RPMs Austin Healey 14
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
A TR2/3/3A checking axle float triumph tr3a Triumph 10
Anthony_S TR2/3/3A TR3a valve cover gasket - checking clearances Triumph 8
RickAnderson Checking an Engine Not in the Car? MG 2
M Checking rear break drums and pads Triumph 7
T Checking OD function w/out solenoid handy? Triumph 4
P Checking oil levels Triumph 6
drooartz Checking transmission/OD levels MG 14
N Checking a rebuilt engine Austin Healey 15
T Anyone interested in checking out a BN2 in NM? Austin Healey 14
M Newbie: Just Checking In MG 7
P CHECKING DIZZY CAP Spridgets 10
Gundy Checking B's tranny oil MG 26
T Checking for front suspension wear Spridgets 4
6 Checking out lever arm shocks Austin Healey 3
drooartz Checking a ribcase transmission Spridgets 2
2wrench Checking the thrust washers.....Dale? Triumph 3
KindredSpirit Just checking about spark plugs. Austin Healey 2
vping Checking an axle ratio MG 2
S TR2/3/3A door strap checking tr3 Triumph 8
M Another New Member - Just checking things out MG 9
G Checking & filling shock absorber fluid Spridgets 9
wkilleffer Checking distributor shaft wobble MG 37
N MGB Checking out MGB's Betwix Here and There MG 3
M Checking/Changing Limited Slip Diff. Oil on XJS Jaguar 2
M Checking a temp guage Triumph 2
aeronca65t Checking Pertronix Unit Restoration & Tools 1
S Paint Checking on the Hood Austin Healey 4
G Checking leak in used radiator Restoration & Tools 3
TNMGB Checking/adding gearbox oil?? MG 34
D Checking Tranny Fluid Level Spridgets 5
N MGB 1978 MGB Coolant Level Checking MG 3
B MGB Another new owner of an MGB checking in MG 9
Andy Blackley Checking my 74B MG 2
mctriumph TR4/4A Busted crankshaft Triumph 7
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
