Ohiobugeye
I have installed a Pertronix ignition system. My set up is 1275 engine using a standard 1275 distributor converted to negative ground, non ballasted . The Module installed with no problems. I was starting from scratch so I didn't have the points or condenser to disconnect or by pass. once the module is installed you have one red wire that connects to the positive terminal to the coil and one black wire that connects to the negative terminal of the coil. The Bugeyes wiring harness has a white wire that connects to the positive terminal to the coil ( neg ground system) that supplies voltage from the fuse block. The harness also has a white and black wire that runs from the negative coil terminal to the distributor under normal conditions. Is it necessary to connect the white and black wire from the coil to the distributor being I now have the electronic ignition installed and am not using the points and condenser?
