Pertronix + MSD ignition problem
Jim_Newman
I have been running a Pertronix Ignitor1 with a Lucas SP12 Sport coil for some time now. The three DCOE 45s could benefit from more complete burning of fuel especially at lower RPMs and the thought of a multiple spark system (MSD) was appealing. So after much review of the pros and cons, I just installed an A6 MSD unit along with a new MSD Blaster2 coil. I also installed a new distributor cap (and yes I ground down the carbon button to make it compatible with the Pertronix. I did not, on advice of MSD install a ballast resistor even though the Blaster2 has a low primary resistance.
Finally, I turned the ignition key on and pushed the start button. She burst into life and sounded pretty good - for about 30seconds. Then all went quite and she refused to restart.
Thinking it might be relasted to the new parts I added, I returned the whole system back to its original set up. Same result.
Upon inspection I can find nothing wrong with the electrical system. No fuses blew, all the ignition wires have continuity. All the wiring is as it was. Everything else works as it did.
Have I fried the Pertronix? Is there some simple test I could make to verify this (other than noting that there seems to be no spark anymore)?
Could it be something else?
As always, any advice and guidance is greatly appreciated.
Cheers
GregW
Platinum
Hi Jim,
What wires did you use to hook the MSD up to the Pertronix? The Violet and green wires?
Jim_Newman
Jim_Newman
Hi Greg
Thanks for responding.
It seems that the violet and green wires, which are from the MSD magnetic pickup connector, are used mainly when wiring into a Mallory9000 series. The instalation instructions for wiring to Pertronox do not specify the magnetic pickup. The MSD is connected to the Pertronix/distributor via the red and white wires.
Jim
Keoke
Sounds like the module was fried to me .Probably should have used the external ballast resistor recommended.--Fwiw--Keoke
Revert back to the original contact points, using the correct MSD wiring schematic, and see if you have *life* again.
In this configuration, the contact points will last a very long time, as they're only being used as the trigger; there's no appreciable current flowing through them.
I'm using the new MSD 6 AL II (digital) with a DP Mallory (second set of points disconnected) and it has made a world of difference at low to slow engine & road speeds.
Jim_Newman
Jim_Newman
You are probably right Keoke. But this is what I received from MSD tech advice people.
"With a Pertronix Igniter and a Blaster II coil ONLY, you will need the resistor.
A Pertronix Igniter and a 6 series ignition unit, you will NOT need the resistor."
This is what made me assume it was something else that went wrong.
Keoke
OK Jim
Randys suggestion of going back to points should get you running I Hope.--Keoke
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
T Pertronix Ignitor: reliability & suitability Austin Healey 10
T Pertronix Ignitor: reliability & suitability Spridgets 19
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
B TR6 Pertronix ignition Triumph 11
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
P Pertronix distributor on an early BJ7 Austin Healey 8
R It wasn't the Pertronix Austin Healey 25
R Suspected Pertronix failure Austin Healey 32
max71 MGB Anyone have experience with the Pertronix Ignitor III? MG 11
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
KVH TR4/4A Report on Pertronix Triumph 6
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
3798j TR4/4A Pertronix III 25d Install Triumph 1
S Points versus Pertronix Spridgets 22
A Spitfire 45DE4 Distributor Pertronix Installation Triumph 2
H TR4/4A Pertronix Ignition Triumph 4
S TR2/3/3A Timing with Pertronix Triumph 12
AUSMHLY Pertronix or points Austin Healey 49
B BN2 Pertronix Question Austin Healey 2
rjc157 Pertronix dist Austin Healey 2
B Pertronix Distributor Wiring? Austin Healey 3
mgbmedic car keeps running after pertronix install MG 11
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
DRKizer Pertronix Flame-Thrower "HP" dizzy for Brit cars Racing 6
B Ignition wires to use with Pertronix distibutor Austin Healey 9
regularman Pertronix Spridgets 28
mountainman pertronix electronic ignition hepl please Triumph 10
T How do you set the timing on a Pertronix distribu Triumph 13
M TR2/3/3A Pertronix coil for TR3 Triumph 7
britndablood Anyone need a pertronix backup pickup for $40 Austin Healey 1
6 Timing Bugeye with Pertronix Spridgets 2
D Spitfire spitfire pertronix installation question Triumph 25
Go_Dogs_Go Convert Pertronix Pos Ground to Neg Ground? Spridgets 10
Michael Oritt Pertronix Ignitor failure mode Austin Healey 8
drooartz Pertronix back to points MG 28
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
T How bench test Pertronix unit Triumph 3
MTribe need help - pertronix trouble at low idle speeds? Triumph 19
F Pertronix Ignition Austin Healey 9
bighealeysource Pertronix coil verus standard Lucas coil Austin Healey 3
E pertronix distributor MG 1
D pertronix for mallory dual point Triumph 5
G Pertronix Flame Thrower Distributor Spridgets 9
KVH TR4/4A Tubular Headers/Pertronix for TR4 Triumph 12
mountainman Pro & Con's of Pertronix vs Points Triumph 43
Seabrook GT6 Pertronix in a MK1 GT6 ? Triumph 3
