BN2 Pertronix Question
bj8bn2
Member
Hi guys,
I installed a Pertronix unit in the dizzy of my BN2 but I don't think it's sitting in the correct place. I did the best I could without doing any cutting or drilling but the screw hole in the Petronix unit does not line up. I tried rotating it all around the distributor plate but nothing matched. Does any one have a picture (close-up) of a properly installed Petronix unit in a BN2 distributor.
I installed a complete Petronix distributor in my BJ8 and it has worked perfectly for 4 years. If you don't care about original looks - I recommend this mod.
Thanks
steveg
Hi guys,
Thanks
Sounds like they sold you an incorrect one. Pertronix tech support told me the modules are the same - it's the base plates that differ.
A BN2 Chassis Alignment Austin Healey 8
T 100 BN2 Possible Ignition Issue Austin Healey 7
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
H BN7 and BN2 Lengths Austin Healey 3
Gundog61 BN2 Brake Drums Austin Healey 5
bighealeysource BN2 Master Cylinder Austin Healey 91
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
MikeAH100M BN2 Tight Steering Austin Healey 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
Guido36 9k-Mile BN2 at Auction Austin Healey 13
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
Guido36 BN1/BN2 Sidescreens Austin Healey 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
J BN2 Shift Lever Bushing Replacement Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
J 100 bn1/bn2 id Austin Healey 26
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
C Wanted 100/4 BN2 1956 Le Mans side windows Austin Healey Classifieds 0
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
A BN2 Boot Lid Austin Healey 4
P BN2 new wood steering wheel install Austin Healey 5
W Gear Lever Boot for BN2 Austin Healey 5
J BN2 shift bushing replacement Austin Healey 5
wangdango BN2 wheel cyclinders/replacement Austin Healey 1
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
P BN2 Walnut Steering Wheel Austin Healey 10
P Healey BN2 Distributor Question Austin Healey 1
