Pertronix Ignitor: reliability & suitability
twas_brillig
There was some discussion regards the Pertronix Ignitor on the Spridget side and I contacted Pertronix, asking if their Ignitor was still subject to failure if it was left switched on without the engine running; if so, how long it could be left before failure; and if the Ignitor II was available for positive ground. Here's their reply:
Doug,
You are correct about leaving the key on. The amount of time is really hard to say for certain. On your application I would estimate no longer than five minutes.
Sorry the ignitor II is not available in positive ground.
Your Pertronix Team,
Marvin Grebow Jr.
Technical Dept.
Michael Oritt
Leaving the ignition on without the engine running will also do in a set of points if they are closed enough for the spark to arc.
steveg
I fried a Pertronix I in a lot less than 5 minutes. IIRC it was closer to 1 minute. The label bubbles when they're fried.
Supposedly the Pertronix II has built-in protection against that, but I don't intend to find out.
If you're doing testing that requires the ignition to be on with the engine off, disconnect the 12v supply wire at the coil.
Keoke
Just don't do none of those bad things The instructions tell U not to do ] U did read them HUH ? [ N they will last forever.----LOL
T
twas_brillig
I read the instructions back in the day, but after ten years or so on the first install.... Good comment on pulling the coil wire - thanks Steve. Pertronix was good about replacing the one I fried a number of years back - can't remember if I paid shipping, but the fix/repair/whatever was no charge. Doug
Keoke
Sorry the ignitor II is not available in positive ground. N Why ????
Marvin Grebow Jr.
Technical Dept.
Keoke
RAC68
Hi All,
Yes, the Crane has external (to the distributor) main components that must be placed in a reasonably cool spot in the engine compartment. However, it seems quite resilient and very stable. I have a Pertronix in my TR7 and I do like the fact it is incognito and haven't needed to touch it for the past 10 years so far. That's still very good reliability.
Ray(64BJ8P1)
dougie
T Pertronix Ignitor: reliability & suitability Spridgets 19
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
max71 MGB Anyone have experience with the Pertronix Ignitor III? MG 11
Michael Oritt Pertronix Ignitor failure mode Austin Healey 8
MGTF1250Dave Pertronix Ignitor Electronic Ignition Installation Triumph 26
MTribe setting static timing with pertronix ignitor Triumph 0
RickB Pertronix Ignitor & Flamethrower kit? Opinions? Spridgets 19
B Pertronix Ignitor Bad? Triumph 7
bluemiata90 Pertronix ignitor, which one to use Triumph 6
Thor Problems fitting Pertronix Ignitor II into 45D CEI Spridgets 6
S Pertronix Ignitor Austin Healey 4
B Pertronix ignitor in Jensen healey Other British Cars 1
D Lucas Sport coil / Pertronix ignitor MG 9
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
B TR6 Pertronix ignition Triumph 11
P Pertronix distributor on an early BJ7 Austin Healey 8
R It wasn't the Pertronix Austin Healey 25
R Suspected Pertronix failure Austin Healey 32
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
KVH TR4/4A Report on Pertronix Triumph 6
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
3798j TR4/4A Pertronix III 25d Install Triumph 1
S Points versus Pertronix Spridgets 22
A Spitfire 45DE4 Distributor Pertronix Installation Triumph 2
H TR4/4A Pertronix Ignition Triumph 4
S TR2/3/3A Timing with Pertronix Triumph 12
AUSMHLY Pertronix or points Austin Healey 49
B BN2 Pertronix Question Austin Healey 2
rjc157 Pertronix dist Austin Healey 2
B Pertronix Distributor Wiring? Austin Healey 3
mgbmedic car keeps running after pertronix install MG 11
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
DRKizer Pertronix Flame-Thrower "HP" dizzy for Brit cars Racing 6
B Ignition wires to use with Pertronix distibutor Austin Healey 9
regularman Pertronix Spridgets 28
mountainman pertronix electronic ignition hepl please Triumph 10
T How do you set the timing on a Pertronix distribu Triumph 13
M TR2/3/3A Pertronix coil for TR3 Triumph 7
britndablood Anyone need a pertronix backup pickup for $40 Austin Healey 1
6 Timing Bugeye with Pertronix Spridgets 2
D Spitfire spitfire pertronix installation question Triumph 25
Go_Dogs_Go Convert Pertronix Pos Ground to Neg Ground? Spridgets 10
drooartz Pertronix back to points MG 28
Jim_Newman Pertronix + MSD ignition problem Austin Healey 6
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
T How bench test Pertronix unit Triumph 3
