Pertronix Ignitor & Flamethrower kit? Opinions?
RickB
RickB
RickB
Hmmm... I just read they had some problems with the manufacturer in China...
Jer
I installed the Petronix distributer (complete distributer)& coil this spring... 3500 miles later & no problems so far
John Moore
I had Jeff at Advance Distributors put one in a recently rebuilt and custom curved Eurospec 45D and it's been great. Very smooth idle and the timing is rock solid. I also like the fact it's all hidden under the distributor cap and no extra boxes or wires. A very clean install.
JeffS
The Pertronix units are fine, but that coil is junk! Its a low quality oil filled coil and durability isn't their strong suit.
I carry the epoxy filled pertronix coils and special order the chrome ones for those who absolutely insist. Another option is the "Bosch Blue" coil which you can get a chrome sleeve for if you insist on chrome.
Its a common misunderstanding that the Pertronix will gain you any performance over a properly adjusted set of points. They will actually hinder the advance curve (slow the retard on decell) which can increase fuel mileage slightly, but not help performance. If you install one in a worn distributor performance will improve, but comparing apples to apples, there's very little difference.
Bugeye58
Thanks, Jeff. I'm a firm believer in points myself.
I even use them to trigger the MSD in the race car.
At least until I install the Electromotive Crank Fire.
Jeff
RickB
RickB
Re: Pertronix Ignitor & Flamethrower kit? Opinions
Thanks Jeff, that's why I went with your advice (and your service).
Very good points,
er... points well taken...
dwell, you know what I mean.
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif /bcforum/images/%%GRAEMLIN_URL%%/thankyousign.gif /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
lesingepsycho
I installed the complete distributor kit from Pertronix and I have been pleased with it so far. I have it triggering my MSD box as well so the ignition is solid. Im using an Accel coil.
I too agree that well built/tuned points dizzes are equally as reliable but the motivations for me to get the pertronix were:
1) the diminishing quality of points coming from the distributors. The rub blocks were wearing down much too quickly for my satisfaction.
2)all the dizzys I had at my disposal had busted collars which made getting them to stay put in the clamp a nightmare.
3)could not firnd a reasonable vacuum advance unit and failed to rebuild one myself.
I didn't kid myself about performance, I just wanted the reliability. So far, so good.
JACK
Bugeye58
As an informational point, I've found that packing the "collar" portion of the distributor body with epoxy such as Devcon (my choice) or JB weld, strengthens that area considerably. I also use a spacer on the portion of the pinch clamp bolt between the ears of the clamp to prevent overtightening to the point of housing failure.
Jeff
RickB
RickB
Jeff
What is the spacer you use Jeff? Something you make yourself? What's it made of? Inquiring minds and all that...
Platinum
Just a piece of tubing, cut to length. The number of dizzys I've seen abused over the years would likely fall into the 1K pounds range. Some folks are just ham-fisted idjits... /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Bugeye58
What Doc said. Nothing fancier than a piece of 5/16" OD tubing such as a chunk of steel fuel line, although I use 17-4 Stainless, turned, drilled and cut on a lathe. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Tighten up the clamp so it's just snug enough to prevent the dizzy from turning, measure the distance between the clamp ears, and cut your tube of choice to that length. Install on the bolt, between the ears, and tighten it up.
Jeff
RickB
RickB
So the purpose of this is to keep you from over tightening the bolt? Is there anything else it does?
jlaird
I just tighten till I can not turn the Dizzy by hand then back the nut off a couple of flats, adjust the timeing and and tighten exactly what I backed off.
The one that came with my parts junk was broken, kind of remeinded me not to do that.
Bugeye58
That's exactly its sole purpose, Rick. I've seen the bolts tightened to the point where they bent, and the ears of the pinch clamp were nearly touching.
Ham fisted Bozos! /bcforum/images/%%GRAEMLIN_URL%%/mad.gif
Jeff
lesingepsycho
Hey! Sounds like mine! Of course I inherited it that way just like I inherited all the busted dizzys!
I do really like the solid mount on the Pertronix however. It would be impossible to break... even by ham fisted bozos /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
JACK
JeffS
I have a repair I do to cracked distributors. I machine off the cracked clamping ring and press/epoxy fit a laser cut steel repair ring. Its as durable as the 45D distributors with a solid housing, and I only charge $20, so its an affordable option to repair an otheriwse useless distributor! With this repair, you can tighten the clamp until the bolt breaks and not harm the distributor!
Jack, Try Standard Ignition's Bluestreak points, part # LU-1617XP. They'll make you forget about Pertronix. Otherwise choice #2 is the brown heel Lucas points BUT you have to file them so sit square to the points cam. More often than not, the points plate is worn so bad that it doesn't sit square to the cam. That means the points don't sit square either, at least not until they wear square (in the first few hundred miles.)
Bugeye58
I've done the same repair, Jeff, except I made the ring from some good aluminum.
Jeff
RickB
RickB
Like many others here have said, Jeff does great work.
I got the thing at the Post Office today (he literally built and shipped it on Friday & I got it today - on Monday!!).
This is a beauty people, Wow - if I didn't know Jeff rebuilt this thing I'd swear it's brand new!
Now I just have to wait until Wednesday to install it after getting my timing light.
T Pertronix Ignitor: reliability & suitability Austin Healey 10
T Pertronix Ignitor: reliability & suitability Spridgets 19
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
max71 MGB Anyone have experience with the Pertronix Ignitor III? MG 11
Michael Oritt Pertronix Ignitor failure mode Austin Healey 8
MGTF1250Dave Pertronix Ignitor Electronic Ignition Installation Triumph 26
MTribe setting static timing with pertronix ignitor Triumph 0
B Pertronix Ignitor Bad? Triumph 7
bluemiata90 Pertronix ignitor, which one to use Triumph 6
Thor Problems fitting Pertronix Ignitor II into 45D CEI Spridgets 6
S Pertronix Ignitor Austin Healey 4
B Pertronix ignitor in Jensen healey Other British Cars 1
D Lucas Sport coil / Pertronix ignitor MG 9
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
B TR6 Pertronix ignition Triumph 11
P Pertronix distributor on an early BJ7 Austin Healey 8
R It wasn't the Pertronix Austin Healey 25
R Suspected Pertronix failure Austin Healey 32
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
KVH TR4/4A Report on Pertronix Triumph 6
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
3798j TR4/4A Pertronix III 25d Install Triumph 1
S Points versus Pertronix Spridgets 22
A Spitfire 45DE4 Distributor Pertronix Installation Triumph 2
H TR4/4A Pertronix Ignition Triumph 4
S TR2/3/3A Timing with Pertronix Triumph 12
AUSMHLY Pertronix or points Austin Healey 49
B BN2 Pertronix Question Austin Healey 2
rjc157 Pertronix dist Austin Healey 2
B Pertronix Distributor Wiring? Austin Healey 3
mgbmedic car keeps running after pertronix install MG 11
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
DRKizer Pertronix Flame-Thrower "HP" dizzy for Brit cars Racing 6
B Ignition wires to use with Pertronix distibutor Austin Healey 9
regularman Pertronix Spridgets 28
mountainman pertronix electronic ignition hepl please Triumph 10
T How do you set the timing on a Pertronix distribu Triumph 13
M TR2/3/3A Pertronix coil for TR3 Triumph 7
britndablood Anyone need a pertronix backup pickup for $40 Austin Healey 1
6 Timing Bugeye with Pertronix Spridgets 2
D Spitfire spitfire pertronix installation question Triumph 25
Go_Dogs_Go Convert Pertronix Pos Ground to Neg Ground? Spridgets 10
drooartz Pertronix back to points MG 28
Jim_Newman Pertronix + MSD ignition problem Austin Healey 6
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
T How bench test Pertronix unit Triumph 3
