Pertronix Ignitor
shorn
lost the instructions, so does anyone know what wires go where when installing a pertronix ignitor in my pos. ground BJ8. Coil is marked SW and GB. Currently present points connect to the GB side.
Dave Russell
Yoda - R.I.P
First, make sure that your Pert. has a black wire & a black white wire. If it has red & black it is for a negative ground car.
Pert. blk/wh wire to coil SW terminal
Pert. blk wire to ignition switch (used to be on the coil SW terminal)
Coil CB terminal to chassis ground (used to go to the points)
S
shorn
Dave, thanks for the info. I didn't want to fry Mr. Lucas by connecting it up the wrong way. Have you had good luck with the Pertronix ignitor?
T Pertronix Ignitor: reliability & suitability Austin Healey 10
T Pertronix Ignitor: reliability & suitability Spridgets 19
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
max71 MGB Anyone have experience with the Pertronix Ignitor III? MG 11
Michael Oritt Pertronix Ignitor failure mode Austin Healey 8
MGTF1250Dave Pertronix Ignitor Electronic Ignition Installation Triumph 26
MTribe setting static timing with pertronix ignitor Triumph 0
RickB Pertronix Ignitor & Flamethrower kit? Opinions? Spridgets 19
B Pertronix Ignitor Bad? Triumph 7
bluemiata90 Pertronix ignitor, which one to use Triumph 6
Thor Problems fitting Pertronix Ignitor II into 45D CEI Spridgets 6
B Pertronix ignitor in Jensen healey Other British Cars 1
D Lucas Sport coil / Pertronix ignitor MG 9
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
B TR6 Pertronix ignition Triumph 11
P Pertronix distributor on an early BJ7 Austin Healey 8
R It wasn't the Pertronix Austin Healey 25
R Suspected Pertronix failure Austin Healey 32
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
KVH TR4/4A Report on Pertronix Triumph 6
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
3798j TR4/4A Pertronix III 25d Install Triumph 1
S Points versus Pertronix Spridgets 22
A Spitfire 45DE4 Distributor Pertronix Installation Triumph 2
H TR4/4A Pertronix Ignition Triumph 4
S TR2/3/3A Timing with Pertronix Triumph 12
AUSMHLY Pertronix or points Austin Healey 49
B BN2 Pertronix Question Austin Healey 2
rjc157 Pertronix dist Austin Healey 2
B Pertronix Distributor Wiring? Austin Healey 3
mgbmedic car keeps running after pertronix install MG 11
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
DRKizer Pertronix Flame-Thrower "HP" dizzy for Brit cars Racing 6
B Ignition wires to use with Pertronix distibutor Austin Healey 9
regularman Pertronix Spridgets 28
mountainman pertronix electronic ignition hepl please Triumph 10
T How do you set the timing on a Pertronix distribu Triumph 13
M TR2/3/3A Pertronix coil for TR3 Triumph 7
britndablood Anyone need a pertronix backup pickup for $40 Austin Healey 1
6 Timing Bugeye with Pertronix Spridgets 2
D Spitfire spitfire pertronix installation question Triumph 25
Go_Dogs_Go Convert Pertronix Pos Ground to Neg Ground? Spridgets 10
drooartz Pertronix back to points MG 28
Jim_Newman Pertronix + MSD ignition problem Austin Healey 6
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
T How bench test Pertronix unit Triumph 3
