jonny,
I've just recently installed an Ignitor and Flame Thrower coil combination in my 71B. Took about an hour, including the re-timing. My 71's old coil was not ballasted, so I ordered the Flame Thrower accordingly. The distrib definitely needed advancing, but not as much as some I'd read about.
Bret's warning is absolutely to be heeded... carefully route the wiring within the distrib, leaving enough length, but not too much. There have been failures attributed to wiring getting worn and shorting due to friction. A small tie-wrap, holding the leads down to the plate just before they leave the distrib, will help. Also, a small dab of silicone sealant on the leads on the outside of the distrib will help keep moisture out.
Plugs: new NGK's, opened them up to 35mm. After roughly 1000 miles, the burn color is perfect.
Performance? I really don't notice much of a boost, but didn't expect any (over properly adjusted points). I went the Pertronix route because my 25D distrib had beginnings of some shaft wear (wobble) that was making it a nightmare to keep the points set. No problem now... no more points float.
spares: I'm currently carrying the points, condensor and screws (don't forget these) as spares, but I'll be ordering another Pertronix unit this week. Will install it, and keep the existing one as a spare. Yeah, I know... but I ask myself what I'd rather be re-installing some rainy night... points or pertronix? Definitely worth the money to me.
quality control: The Pertronix units tend to fall into 2 categories: those that fail pretty quickly, and those that run smoothly for years. And when they fail, they go immediately (at least points start deteriorating slowly). However, if needed, I hear that their customer support is outstanding.
Good luck, and may it go as well for you as it did for me.
Dave
