On a positive note - new Bosch alternator rocks!
tdskip
I had to customize the bracket some to get the correct fan belt tension but I just started her up and, well, she started which is a good first step.
It was pretty amazing to see how much brighter her headlights and dash lights were. Yea!
Brosky
You can now turn on the heater fan AND the lights and they both work on high!
kodanja
& the Radio too!
I haven't had a single problem since I changed over!!
kodanja
its a Apline system with a 1600 watt amp, 2-5.5" in the kidney pads and 6x9's behind the seat.
I cant help it I was born in 1960 with an older brother & sister into real rock!
Platinum
*GROAN*
:jester:
Brosky
They do make for a nice background at shows, but I have yet to use mine while driving. But I DO NOT have what Bill has to blast with either!
kodanja
You traditionalist!'
Crank up the tunes!
Gliderman8
Tom-
Which Bosch alternator did you use? Part number and or vendor where you got it.
I will be looking to upgrade mine from the stock Lucas. By the way, was it "plug and play" or did you have to modify any of the wiring?
Thanks for the info.
kodanja
An alternator is an electromechanical device that converts mechanical energy to alternating current electrical energy. Most alternators use a rotating magnetic field but linear alternators are occasionally used. In principle, any AC electrical generator can be called an alternator, but usually the word refers to small rotating machines driven by automotive and other internal combustion engines. In UK, large alternators in power stations which are driven by steam turbines are called turbo-alternators.
swift6
These two big pipes under the bumper are the only sound system I need in my TR6. Those thar loudspeakers make beautiful music with superb soundstaging and range. :wink:
TonyPanchot
A great post
I still employ the original AM Triumph radio
rather prefer the exhaust note of the Monza
right on Shawn
I sure miss CO. ( Parker )
spent a lot of time at the FCB it is an A-B thing pre In-Bev
TR3driver
Great Pumpkin - R.I.P
Re: On a positive note - new Bosch alternator rock
Worth noting perhaps, that automotive alternators generate relatively high frequency 3-phase AC, which is then rectified into DC by solid-state diodes contained within the unit. They offer a number of advantages over the DC generators used on earlier Triumphs, including higher output, smaller size, lighter weight and higher efficiency. Pretty much all electrical power generation is done by alternator these days; although solar cell usage is growing.
Here's a video of some cool old alternators (and the engines that turn them) https://www.youtube.com/watch?v=HHvUTv9AwxA
The one on the right used to power the city of Avalon on Catalina Island.
kodanja
Sometimes I just listen to my monzas, but on a long ride they give me a headache.
I either need to get a quieter exhaust system or a louder stereo
Crisis
How do you house the rear speakers? I a box? Sitting on floor? Just curious as I would like to upgrade mine. Currently just 2x6'' in the kick panels (TR6). I know thats not correct but the PO did this.
Brosky
Bill,
How are they with the hard top on? The Monza's that is?
swift6
I don't like the Monza "drone' either and the Monza's are louder that the Twin Sport system. The Twin Sport system settles into a nice mellow tone when cruising too.
B Positive-Ground LED Light Strip Austin Healey 8
P Positive to Negative Conversion Austin Healey 1
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
M 66 ‘ BJ 8 Positive ground identification Austin Healey 4
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
R TR2/3/3A Positive-ground LED lights Triumph 13
Sopwith_Camel positive camber xj Jaguar 0
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
M TR2/3/3A Positive or negative ground? Triumph 6
P Jump starting a positive ground BJ8 Austin Healey 4
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Question about positive vs negative ground Spridgets 13
K TR2/3/3A Converting to Positive Ground....... Triumph 1
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
DanLewis Correcting positive camber in a Bugeye Spridgets 21
M LED lamps for Austin Healey with positive ground Austin Healey 0
Lukens What's the down side of "positive ground system"? Triumph 8
P TR4/4A Positive/Negative Earth Dilemma TR4A Triumph 11
P How to use timing light with positive ground? Austin Healey 14
C Positive or Negative Earth Triumph 15
R 66 midget tach positive ground Spridgets 2
Mowgli81 Positive Ground Disconnect in Trunk Austin Healey 4
E Positive ground or Negative ground. What have you? Austin Healey 12
C Positive Ground History with Triumph Motorcycles British Motorbikes 1
Geo Hahn Brakelight Flasher for Positive Ground Triumph 2
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
cbrvfr Running modern accessories with positive ground? Austin Healey 4
S positive and negative ground Triumph 7
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
memphis Positive to Negative Conversion Austin Healey 2
BOBBYR Positive ground dwell Austin Healey 23
PatGalvin Any Issues with Jump Start of Positive Earth LBC Triumph 9
T Why positive ground? Austin Healey 17
S Size 34 Optima Battery w/positive ground Austin Healey 33
J Jump Starting Positive Earth cars. Austin Healey 3
M Jump start positive ground car Austin Healey 10
I Bugeye-better to have negative or positive ground? Spridgets 17
JohnnyMead Relays for Positive Ground Triumph 6
T TR4/4A TR4a positive or negative earth? Triumph 17
