Relays for Positive Ground
JohnnyMead
I'm thinking about using relays in the headlight circuit of my still positive ground TR3. Can I use the common cube-style automotive relays? It seems like the relay coil could be wired either way.
Thanks,
John
TR3driver
Great Pumpkin - R.I.P
For the most part, yes. The common relays don't care about polarity, however some of the sockets sold with them have suppression diodes wired into the socket. They will also work fine, as long as you observe the polarity of the diode.
JohnnyMead
JohnnyMead
Thanks Randall. What I'm thinking about is a relay to substitute for the dimmer switch. With my long legs and clumsy feet I don't have much foot room between the dimmer bracket and the clutch. A relay and a little switch under the dash would eliminate the bracket.
Anyway, its winter here and I'm dreaming up silly little projects!
John
TR3driver
If you are going to go that far, why not use two relays? That way the headlight current doesn't go through the original panel switch either, which extends the life of the switch and gets just a bit more power to the bulbs for brighter lights.
I'm actually going rather overboard and using 4 relays on my TR3, one for each filament, so I can have separate fuses for each side. I had only two relays on the TR3A, with a fuse for each one; but having one of the fuses fail while descending a mountain at 80+ mph on a dark night convinced me that I would really rather have separate fuses for each side.
JohnnyMead
JohnnyMead
Yes, in fact I was thinking about a relay for the light circuit. I like your multiple relay design. Where did you mount them?
TR3driver
For the current project, I am mounting them on the back of the headlight buckets, where they will be mostly out of sight and yet easily accessible (by pulling the bucket). The main harness will remain intact and original, with the only visible mods being a new Lucas fuse block near the original one, and two wires from the new fuse block to the relays. My theory is that the headlight pigtails will also look fairly stock, except for the extra wire.
But I haven't gotten very far with it; got distracted when I realized that the original brake light switch only comes on when I'm about to lock up the brakes. In between rain drops, I've added a bracket to mount a mechanical switch so it rides on the pedal. Here again I wanted to hide it, so it's under the dash this time (TR3A had it mounted on the pedal box under the hood, where there is a very convenient original hole).
PS, I also discovered that my right headlight is losing over 1/2 volt inside the original headlight connector. Both sides will be getting new connectors along with the relays.
JohnnyMead
JohnnyMead
Yeah, I've seen posts about the stock brake light switch. All my old cars (jeeps, VWs, and so forth) have had the brake fluid activated switches, but my every day modern cars all seem to have pedal micro switches.
Thanks again for the relay ideas.
John
S Overdrive Relays Austin Healey 2
lram59 TR4/4A Hide away relays Triumph 2
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
G Power to relays Austin Healey 10
Spock TR6 '72 Headlight Relays Triumph 4
M Headlight relays Austin Healey 17
4tecdog Headlight relays the easy way Austin Healey 13
Jim_Gruber BE Hi Low Beam Footswitch and Relays Spridgets 6
PAUL161 General Tech Electrical Relays MG 16
MikeAH100M How Many BN2 Overdrive Relays?? Austin Healey 2
S Headlamp Relays vs. New Headlamp Wiring Harness Austin Healey 6
B Horn/Headlight Relays Spridgets 13
L BE Headlight Relays- Photos Spridgets 1
Gliderman8 Headlight relays!..... Triumph 24
T 3 Speed to 4 Speed Overdrive Relays Austin Healey 0
wkilleffer Adding relays to the low and high-beam circuits MG 10
D Adding electrical relays, to save old stuff Triumph 16
RickB Installed relays for halogens yesterday Spridgets 18
JPSmit Todays question - relays Spridgets 13
B Headlight relays Spridgets 2
E Can anyone suggest a source to id Hella relays? Jaguar 1
TR674 Relays Triumph 3
G Headlight relays Spridgets 11
Simon TR4a Wiper installation question, and relays. Triumph 0
I Relays Triumph 3
71tr electrical relays Triumph 2
Alan_Myers Lucas relays & headlamps Triumph 19
W relays Jaguar 12
B Positive-Ground LED Light Strip Austin Healey 8
P Positive to Negative Conversion Austin Healey 1
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
M 66 ‘ BJ 8 Positive ground identification Austin Healey 4
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
R TR2/3/3A Positive-ground LED lights Triumph 13
Sopwith_Camel positive camber xj Jaguar 0
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
M TR2/3/3A Positive or negative ground? Triumph 6
P Jump starting a positive ground BJ8 Austin Healey 4
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Question about positive vs negative ground Spridgets 13
K TR2/3/3A Converting to Positive Ground....... Triumph 1
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
