BJ8 Positive-Negative Ground Conversion
metropolisman
Good morning,
I've followed the instructions many people have posted about converting my car to negative ground, this is likely a silly question but I will put it out there just the same. There is a grounding strap from the master battery disconnect switch to the frame rail in the boot. I assume since that switch will be hot that that strap would energize the body and that strap will need to be removed. Do I need to provide any additional grounding to the negative battery terminal? Thank you in advance for anyone’s advice. Best, Jeff
dklawson
Re: Bj8 positive negative ground conversion question
Focus on the battery. The cable/component presently connected to battery (-) should be moved to battery (+). Likewise, what is presently on battery (+) should be moved to battery (-). That should handle all the main and switched connection.
After that you have to focus on the loads connected to the battery. Those would include things like the cap or filter on an electric SU fuel pump, converting any electric gauges (i.e. Ammeter), reversing the coil connections, and re-polarizing the generator.
RTaillieu
You have to turn the battery around and connect the positive terminal to the cable that goes to the solenoid and the negative terminal to the disconnect switch and chassis ground.
M
metropolisman
So the chassis ground would remain connected to the switch and now positive battery terminal?
Keoke
So the chassis ground would remain connected to the switch and now positive battery terminal?[/QUOTE
Read the above RTaillieu post carefully.
John Turney
Good morning,
The grounding strap from the master battery switch to the frame remains as is. Turning the master battery switch to "Off" disconnects the battery from ground. On a positive ground car, the insulated cable from the master battery switch to the battery goes to the + battery post. The cable to the starter solenoid goes to the - battery post. When you turn the battery around, the cable to the starter solenoid goes to the + battery post, and the insulated cable from the master battery switch to the battery goes to the - battery post. Having the master battery switch turned to "Off" still disconnects the battery from ground, which is now negative. You did turn the master battery switch to "Off" before starting this procedure, didn't you?
Hope this helps.
Healey Nut
Turn the battery round , reconnect . Do not remove any cables .
Modify tachometer wiring as needed . Re-exite winding on generator . Check polarity on fuel pump (if its electronic )
Start her up .
Legal Bill
Hope this helps.
Mertopolisman, if, after reading John's very carefully written explanation above you are still confused about what to do, please stop and seek professional, or at least experienced help with your conversion.
R Positive to Negative Ground Conversion BJ8 Austin Healey 3
P Jump starting a positive ground BJ8 Austin Healey 4
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
