positive camber xj
Sopwith_Camel
ok I just did the left rear wheel bearing on my 95 x300 XJ6, we got every thing resembled but we can rock the wheel back and forth on the Z axis, along the length of the car. X being the axle. it seems to be moving a lot in and out of the Dif. the other side (right) is rock steady.
ideas should i be worried?
ok the story so I need the left wheel bearing done so yesterday, a holiday, a buddy of mine put it up on a 2 post lift at his work place, A cave in a mountain where the towns swerplant is. we repacked the main bearings, beacause the part supplier sent me the same bearings in different boxes, inner and outer. much swearing later, re packed the original bearings, the fulcrum bearings one was very rusty but in knocking out the ring we broke the alumminum housing , more swearing. this morning I hoped over to the local meclaial place that dose snow plows and heavy equipment. they said no to welding the aluminium. my buddy made some calls to where he use to work on building oil rigs. so i bombed down in the Sprite and they welded up the aluminium in no time and didn't charge me!!! I drove the back way home, its like driving a roller coast, top down in the sprite. ok so i have to meet up with my friend at 6 to put the repaired hub career back in the jag. but the town has dug up the road so much by my house the sprite died at an intersection. a rock had puncture the fuel line at the pump. and a wire had popped off the Distributer !! while i was under the car getting covered with gas my boss walked up with his dughter, ill hear about that tomorrow. so I got the sprite sorted, always have a leather man, and i got to the Cave at about 6:20, an quickly popped the pivot bearing in, and got the wheel assembly re assembled.
xj needs wheel nut torqued to 300
mk2 needs transmission rebuild
mgb waiting on front claipers
sprite needs new tach, and fresh gas hoses.
I'm having a gin and tonic.
DanLewis Correcting positive camber in a Bugeye Spridgets 21
Trevor Jessie Positive camber Spridgets 20
Mark_Gibson TR6 TR-6 Positive Rear Wheel Camber Causes Triumph 8
Mark_Gibson TR6 Positive Camber Solution for TR-6 Triumph 0
B Positive-Ground LED Light Strip Austin Healey 8
P Positive to Negative Conversion Austin Healey 1
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
M 66 ā€˜ BJ 8 Positive ground identification Austin Healey 4
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
R TR2/3/3A Positive-ground LED lights Triumph 13
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
M TR2/3/3A Positive or negative ground? Triumph 6
P Jump starting a positive ground BJ8 Austin Healey 4
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Question about positive vs negative ground Spridgets 13
K TR2/3/3A Converting to Positive Ground....... Triumph 1
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
M LED lamps for Austin Healey with positive ground Austin Healey 0
Lukens What's the down side of "positive ground system"? Triumph 8
P TR4/4A Positive/Negative Earth Dilemma TR4A Triumph 11
P How to use timing light with positive ground? Austin Healey 14
C Positive or Negative Earth Triumph 15
R 66 midget tach positive ground Spridgets 2
Mowgli81 Positive Ground Disconnect in Trunk Austin Healey 4
E Positive ground or Negative ground. What have you? Austin Healey 12
C Positive Ground History with Triumph Motorcycles British Motorbikes 1
Geo Hahn Brakelight Flasher for Positive Ground Triumph 2
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
cbrvfr Running modern accessories with positive ground? Austin Healey 4
S positive and negative ground Triumph 7
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
memphis Positive to Negative Conversion Austin Healey 2
BOBBYR Positive ground dwell Austin Healey 23
PatGalvin Any Issues with Jump Start of Positive Earth LBC Triumph 9
T Why positive ground? Austin Healey 17
S Size 34 Optima Battery w/positive ground Austin Healey 33
J Jump Starting Positive Earth cars. Austin Healey 3
M Jump start positive ground car Austin Healey 10
I Bugeye-better to have negative or positive ground? Spridgets 17
