Brakelight Flasher for Positive Ground
Geo Hahn
In another thread these units were discussed -- they pulse the brake lights a few quick times with each use. One issue for some of us is finding a model that will work with positive ground (w/o an elaborate work-around or hack).
I contacted one seller and he agreed to make me a positive ground version of the unit he sells. He tells me that his units work with either incandescents or LEDs and can be used for the entire set of brake lights (up to 12a). Here is his update:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Thank you for the payment. I started work on your flashers this evening. I thought I could just modify the existing design but it didn't work so I am starting over from scratch. It may take a little longer than a week like I initialy told you. Will that be a problem? Hopefully just a day or two. I need to make a new PCB layout and then build a prototype and test it, and then on to making an actual product that I can sell. Once the design is done, I can easily mass produce these so it will be no problem for in the future as others order them. I just wish I had thought to do this sooner. I guess I didn't realize there was a need for these for people running a positive ground system.
As for future sales....the price would be $18.00 plus $1.80 shipping in the lower 48. Outside the lower 48 the shipping would be by location but the price would still be $18 US dollars. This price is for British car owners only though.
Thanks again and let me know if you have any other questions. I will keep you updated.[/QUOTE]
So, I should have one soon and will report here on how it works. Meanwhile, the seller (Cody) can be contacted at ck<span style="font-style: italic">-dot-</span>technologies<span style="font-style: italic">-at-</span>hotmail<span style="font-style: italic">-dot-</span>com.
If you want to see his eBay listing for the negative ground version it is here: eBay listing
BTW -- Cody has a fine looking chrome bumper MGB so he was very understanding of the plight of those of us still living in a positive ground world. NFI of course, just passing along what I have learned & done.
JohnB
Bronze
Thanks for doing the groundwork for us.
I'll be ordering one for myself.
CJD TR2/3/3A TR3 Brakelight Switch and Silicone Fluid Triumph 17
DrEntropy Brakelight switch R&R contest. Spridgets 1
roofman 3rd brakelight installed whatcha think? Triumph 45
T Lucas Flasher Unit Austin Healey 5
P Flasher Unit Austin Healey 4
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
6 Turn Signal Flasher Spridgets 8
B Flasher Unit Austin Healey 1
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
BN6_2197 How does the flasher unit work Austin Healey 4
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
R TR2/3/3A Flasher Unit, A Clue? Triumph 11
R For Sale Misc. TR-4 signal and flasher parts Triumph Classifieds 0
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
N Turn signal flasher?? Spridgets 8
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
Lukens TR2/3/3A Led flasher relay? Triumph 3
PAUL161 T-Series Turn Signal Flasher MG 8
G TR4/4A Flasher Unit...VERY hot Triumph 10
pkmh Humorous moment while detailing Healey flasher unit Austin Healey 5
RAC68 Lost 8 terminal Flasher Relay Plan Austin Healey 39
Gliderman8 TR6 Correct LED flasher relay Triumph 6
F TR2/3/3A Direcional Flasher Problem Triumph 12
Jim_Gruber Turn Signals and Flasher Lamp on Dash Spridgets 8
Marla TR4/4A Flasher Triumph 10
K TR2/3/3A Correct position for flasher bracket? Triumph 7
B TR2/3/3A Flasher Unit operation Triumph 4
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
KVH TR4/4A Turn Signal Flasher and Perceptions Triumph 3
KVH TR4/4A Three Questions: Distributors, Idling, Turn Signal Flasher Triumph 29
G TR2/3/3A Flasher mount Triumph 12
sundown TR6 1973 TR6 flasher question Triumph 6
K TR2/3/3A Turn signal flasher stays on? Triumph 3
T TR2/3/3A Flasher indicator dash light Triumph 3
T TR2/3/3A Flasher problem Triumph 12
I TR6 Any tips on removing flasher switch Triumph 3
I TR6 Turn/flasher help Triumph 8
BN6_2197 Question on flasher of BN6 Austin Healey 28
T TR4/4A Question on mounting front flasher lights Triumph 6
D TR4/4A Elec Flasher/LED bulbs revisited Triumph 14
H Up-dated Flasher Relay Unit for Austin Healeys Austin Healey 1
M TR2/3/3A Rear flasher lamp replacement Triumph 10
R 100-4 flasher unit buggin' me Austin Healey 2
R Diagnosing flasher relay Austin Healey 4
R 100-4 flasher relay Austin Healey 0
R troubleshooting flasher relay box Austin Healey 7
af3683 TR2/3/3A TR3B Signal Flasher Problem? Triumph 2
JFS Wedge TR8 Hazard Flasher Triumph 15
M Flasher for LEDs Austin Healey 2
bighealeysource LED bulbs and electronic flasher module issues Austin Healey 26
