Any Issues with Jump Start of Positive Earth LBC
PatGalvin
Hey guys
My new 65 Herald is Positive Ground. I jumped it with my Suburban and then thought "hey, I wonder if this might be a stupid thing to do...?" Any issues with jump starting a positive ground car with a negative ground car?
When I was in Jr. High, I borrowed the family Mercury Wagon (390 CI) and learned how to remove the battery and clean and reinstall. I put it in backwards and then learned how to replace alternator diodes. Don't want to repeat that performance 40 years later...
Pat
Twosheds
No issues as long as you connected positive on one battery to positive on the other battery and negative to negative.
martx-5
Just make sure that the two vehicles are not touching each other. :eeek:
tinman58
I lust jumped a 2006 Corvette with no ill effects. Took a little to charge his battery,
luke44
Just askin' - wouldn't you connect ground to ground and hot to hot? Ie - opposite of above?
HerronScott
Luke,
No! You definitely want to observe battery polarity. Batteries don't care which end is grounded.
Scott
TR3driver
Great Pumpkin - R.I.P
Only if you crave excitement !
:devilgrin:
Seriously, there is a potential for fire and/or explosion if you connect the batteries backwards. As several people have said above, observe the <span style="font-weight: bold"><span style="font-style: italic">battery</span></span> polarity and ignore which terminal just happens to be connected to the car body (aka ground, which of course isn't ground at all).
luke44
It's been a long time since I jumped a positve earth car. Thanks for the heads up. Good to know. (not that these cars ever get flat batteries, right?)
Deanrobert Xke series lll cooling issues Jaguar 5
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
drustom fueling issues Restoration & Tools 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
Celtic 77 MGB 77 Stromberg issues MG 12
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Celtic 77 MOSS response issues Restoration & Tools 11
A Spitfire Spitfire Fuel pump issues Triumph 5
Celtic 77 MGB 1977 MGB Brake issues MG 8
I Bugeye charging issues Spridgets 8
K TR2/3/3A TR-3B carburator issues Triumph 2
T TR6 Continuous Starting and Ignition Issues Triumph 6
E MGB MG Idle issues, restart issues solved. MG 4
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
J Wiring Harnesses Issues Spridgets 3
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A TR3A electrical issues Triumph 2
R TR6 1973 Final drive issues Triumph 5
G 79 Midget Clutch issues Spridgets 9
Dnickels Spitfire Spitfire lighting issues Triumph 4
I TR6 Dash light issues Triumph 19
Rob Dodge Trafficator arm issues. Jaguar 2
M 1972 Midget Engine Issues Spridgets 10
R TR6 Gearbox rebuild issues Triumph 8
A Front wheel bearing issues Austin Healey 11
T 100-6 start up issues Austin Healey 6
N Electrical Issues Need Help Austin Healey 8
sundown TR6 Fuel issues Triumph 5
R TR6 Clutch issues Triumph 7
K TR2/3/3A Up-date TRF points issues resolved. Triumph 0
K TR2/3/3A Friends TR3 has carb issues? Triumph 5
N TR6 Electrical Issues Triumph 5
FlyingCat Spitfire Clutch Issues Triumph 8
F TR6 Carburetor issues at low rpms webers Triumph 23
S TR2/3/3A Wet liner issues Triumph 6
R BN7 Speedometer issues Austin Healey 1
steveg Steering rebuild followup - still issues Austin Healey 29
2 TR2/3/3A Coil issues Triumph 31
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
Joe Reed General MG MG Driver back issues....FREE! Anyone want them? MG 4
bighealeysource Turn signal issues Austin Healey 6
D Healey 100 issues Austin Healey 15
S TR2/3/3A Overdrive Solenoid Issues Triumph 11
TEM666666 Sprite Chrome Hubcap Fitment Issues? Spridgets 4
B TR6 Starter Issues Triumph 7
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
