fueling issues
drustom
what do I do if such a mistake should happen (putting petrol into a diesel car)? i heard alot of stories about people making this mistake ... anyone knows something about the possible damage it could cause to an engine?
mezy
How much petrol to diesel,
Not a good idea, running it at all, a friend of mine did it, maybe 5 litre of petrol, but then filled it up with diesel, then run it dry.
Thought he had got away with it, a month later there was a pool of oil on the drive from the turbo.
may or may have not been related, but i would imagine the raised exhaust temp from the petrol could have blown the turbo seals.
LarryK
Smell nozzle before putting in filler. If the mistake happens and you catch it, tow home and drain immediately, pour fresh gas, infected fuel line at engine and pump the fresh gas into a can. If it smells like gasoline refasten lines, add injector cleaner to fuel, then run.
R GT6 GT6 Fueling Issues Triumph 27
S wrong fueling Restoration & Tools 5
Deanrobert Xke series lll cooling issues Jaguar 5
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
B TR4/4A Steering Wheel Hub Issues Triumph 0
Celtic 77 MGB 77 Stromberg issues MG 12
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Celtic 77 MOSS response issues Restoration & Tools 11
A Spitfire Spitfire Fuel pump issues Triumph 5
Celtic 77 MGB 1977 MGB Brake issues MG 8
I Bugeye charging issues Spridgets 8
K TR2/3/3A TR-3B carburator issues Triumph 2
T TR6 Continuous Starting and Ignition Issues Triumph 6
E MGB MG Idle issues, restart issues solved. MG 4
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
J Wiring Harnesses Issues Spridgets 3
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A TR3A electrical issues Triumph 2
R TR6 1973 Final drive issues Triumph 5
G 79 Midget Clutch issues Spridgets 9
Dnickels Spitfire Spitfire lighting issues Triumph 4
I TR6 Dash light issues Triumph 19
Rob Dodge Trafficator arm issues. Jaguar 2
M 1972 Midget Engine Issues Spridgets 10
R TR6 Gearbox rebuild issues Triumph 8
A Front wheel bearing issues Austin Healey 11
T 100-6 start up issues Austin Healey 6
N Electrical Issues Need Help Austin Healey 8
sundown TR6 Fuel issues Triumph 5
R TR6 Clutch issues Triumph 7
K TR2/3/3A Up-date TRF points issues resolved. Triumph 0
K TR2/3/3A Friends TR3 has carb issues? Triumph 5
N TR6 Electrical Issues Triumph 5
FlyingCat Spitfire Clutch Issues Triumph 8
F TR6 Carburetor issues at low rpms webers Triumph 23
S TR2/3/3A Wet liner issues Triumph 6
R BN7 Speedometer issues Austin Healey 1
steveg Steering rebuild followup - still issues Austin Healey 29
2 TR2/3/3A Coil issues Triumph 31
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
Joe Reed General MG MG Driver back issues....FREE! Anyone want them? MG 4
bighealeysource Turn signal issues Austin Healey 6
D Healey 100 issues Austin Healey 15
S TR2/3/3A Overdrive Solenoid Issues Triumph 11
TEM666666 Sprite Chrome Hubcap Fitment Issues? Spridgets 4
B TR6 Starter Issues Triumph 7
