wrong fueling
sprocket1
what do I do if such a mistake should happen (putting petrol into a diesel car)? i heard alot of stories about people making this mistake ... anyone knows something about the possible damage it could cause to an engine?
TR3driver
Great Pumpkin - R.I.P
Depends on the engine. In some cases, it can ruin the injector pump, which is muy dinero to repair. The basic approach if it does happen is to stop the engine immediately, have it towed if necessary, and clean out the contaminated fuel entirely, including all the filters etc. Then put in some fresh fuel and try to get it running again.
:iagree:
Gasoline is much more volatile than diesel, so if you were to try and run a diesel engine on it there would be very little power- the gasoline would ignite too soon and burn too quickly where the diesel is heavier and ignites under very high compression and burns longer for the expansion stroke. The analogous situation for a gasoline engine would be if the ignition timing were set to spark before the piston reached TDC. So, running a diesel engine on gasoline is plainly a bad idea- and the injectors themselves are intended for a thicker fuel.
So if you do fill your diesel car with gasoline, do not drive it or attempt to start the car at all. Have the gasoline drained completely. If you start the car all that does is increase the number of items that need cleaning- fuel line and pump, filter, injector pump and hoses. Injector pumps are designed to run with a particular sort of fuel, too thick and it's too hard to push the stuff with sufficient force (see following comments on vegetable oil), too thin and the pump might not get the lubrication that oilier fuel provides and may overheat or wear.
You may have noticed that I've had a topic "Bio-Diesel" in the "Pub" in which I've discussed running a diesel car on vegetable oil- that fuel is much more similar to diesel than gasoline and it will work quite well in many engines during warm weather.
In running engines on vegetable oil that fuel is thicker than diesel, so then some people use small amounts of gasoline to dilute it somewhat and thereby remedy some of the cold starting/running issues involved with using that kind of fuel.
In fact, if you accidentally put a SMALL amount (say less than 5%gasoline/95%diesel- maybe more, but I'd not suggest you gamble on that) of gasoline in your diesel car it will not be affected by that, provided it's diluted to the point where the gasoline is only a small proportion of what the car runs on.
This past winter I found the vegetable oil I used wouldn't allow me to start the car- so I had to use starting ether, a very volatile gas. The car would start very easily, but there'd be a lot of white smoke and valve clatter, and with the thick oil it'd run raggedy until the car had warmed up enough. I suspect that if you tried to run the engine on gasoline excess smoke and valve clatter would be the result, though perhaps not so bad as with a 20 second squirt of really volatile gas that was then immediately burned off.
I hope this helps.
S
sprocket1
OK. So if anything like that happens...I am really...s****ed. :smirk: It is much easyer for petrol cars, since diesel nozle is wider than petrol one, so it is impossible to insert diesel nozle into petrol car.
Yes, a little petrol (like if you start and very quickly realize the mistake- say 2 or 3 liters for a 50 liter tank) probably wouldn't be too bad, but if you put a lot in and then drive it I suspect you'll damage something.
I once put petrol (40 liters- way too much to try and run it) in my Diesel car, but realized my mistake before I'd started it. Just had to push it to one side and call a garage to come get it and drain the tank. What an aggravation, but it was less bother and cost than a messed up engine.
Platinum
Mechanical diesel pumps count on the fuel for lubricant. Running gasoline thru one will trash it. Exploding gasoline in a diesel engine in place of diesel amounts to the same thing. BIG mess.
lram59 TR4/4A What's wrong with this picture? Triumph 4
B TR4/4A What did I do wrong? Triumph 19
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
S TR2/3/3A I've been wrong for 60+ years: it looks like it's NOT a 1959 Triumph 8
SD Bugeye What is wrong with people Spotted 4
K TR2/3/3A What's wrong at The Roadster Factory? Triumph 5
D Which part is wrong... Spridgets 9
B All the coolant in the wrong place Spridgets 17
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
Jim_Gruber So what did I do wrong here with Bugsy. Spridgets 2
CJD TR2/3/3A Wrong OD Relay? Triumph 16
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
TomMull Off Topic BAT: I know this is in the wrong category but It's following the BAT discussion here. Triumph 6
TomMull TR2/3/3A Wrong SU jet? Triumph 0
P Coolant level indicator wrong? Jaguar 4
KVH TR4/4A Wrong Threads on New Fuel Pump? Triumph 13
B TR2/3/3A I think I've got the wrong seats. Now what? Triumph 13
L TR5/TR250 Brake bleeding….what am I doing wrong? Triumph 4
K TR2/3/3A Clutch Operating Shaft with bolt hole in wrong location? Triumph 3
TRMark What could possible go wrong? Restoration & Tools 4
DanLewis Wrong dipstick? Spridgets 37
M TR2/3/3A Indiactor light wiring. Is this what I'm doing wrong? Triumph 7
catfood Whats wrong with this BN1 Austin Healey 14
C TR2/3/3A Wrong slave cylinder Triumph 3
A What's wrong with my TR4a? Triumph 6
RickB I was wrong. Again. Not ignition switch! Spridgets 16
M TR2/3/3A TR3 slave cylinder, What I'm I doing wrong Triumph 2
tinman58 TR2/3/3A somthing's wrong. Triumph 10
DNK Wedge What's wrong with this Pic? Triumph 12
Jim_Newman Where did I go wrong? Austin Healey 37
SMGoose Wrong Clutch Disc? Triumph 2
Hap Waldrop wrong forum, opps, Spridgets 1
R First timer posting in wrong section.. Spridgets 2
M Cutch Slave Cylinder what am I doing wrong [pics] Triumph 6
T Torque steer from the wrong end of the car Triumph 7
T pistons wrong way round Austin Healey 22
JPSmit Wrong bleeping coast again Spridgets 5
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
I Bare metal respary going horribly wrong Austin Healey 8
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
T T-Series MG TF Notchy Steering - What is wrong? MG 4
J Cost for front suspension refurb right/wrong? Spridgets 8
Got_All_4 TR2/3/3A What's wrong with this brake fluid? TR3 Triumph 19
swift6 Correct me if I am wrong... Please... TVR 20
texas_bugeye oops stack on the wrong end Spridgets 5
TR6oldtimer TR6 What's wrong with this carb '73 TR6 Triumph 7
A sloppy shifter !! somthing must be wrong Triumph 7
G I bought the wrong oil pump Spridgets 5
UmmYeahOk I dont know if this is really cool or really wrong Triumph 18
D Wedge TR7 Parts f/s what am I doing wrong? Triumph 7
