TR5/TR250 Brake bleeding….what am I doing wrong?
Leo_250
In bleeding the brakes on my 250 I make sure the PDWA cylinder is centered then I bleed the right rear, left rear, right front and then the cylinder pops to the side and I can't continue the process. What am I doing wrong??
poolboy
You may be pushing the brake pedal down too fast
Also be aware of the 2 compartments in the reservoir..The small one in the front is for the rear brakes and it doesn't take that many pumps to empty it..
Once empty, the shuttle within the PDWA may react to the lack of fluid pressure in the rear brake lines.
TR3driver
Great Pumpkin - R.I.P
Also, having the PDWA shuttle to one side should NOT keep you from bleeding the brakes. It doesn't shut off the flow, just operates the switch. (Hence the "Warning Actuator" part of the name.)
Tybalt
My experience is that the PDWA shuttle piston has to be recentered every time I bleed the brakes as the reduced pressure will cause it to move in the bore of the PDWA body. I have never had an out of center position PDWA piston prevent me from successfully bleeding the brakes. While I have always done the book method of recentering the piston with minimal problem, I know that some have pulled the PDWA switch out and used a small punch or heavy pick to catch the shuttle piston and manually recenter it in the PDWA.
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Govtslug TR6 Brake Bleeding Triumph 58
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
N Need brake bleeding advice Spridgets 6
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
nevets brake bleeding Austin Healey 13
vickxxx T-Series Brake bleeding MG TD MG 10
R General Tech One Person Brake Bleeding with a Mityvac Triumph 12
Simmo Series 3 E Type Brake Bleeding Jaguar 2
jlaird Brake and Clutch bleeding Spridgets 7
N Need Brake Bleeding Help Spridgets 25
J TR2/3/3A Brake Bleeding problem on a TR3A Triumph 19
T TR2/3/3A One Person TR3 Brake Bleeding Option? Triumph 11
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
nevets Question about brake bleeding Austin Healey 13
D TR6 76 TR6 New Brake Bleeding Triumph 4
KVH Bleeding the Brake Master Cylinder Triumph 8
B Brake bleeding issues....Help please... Triumph 16
D Dual Circuit Brake Bleeding Triumph 7
W Off to the local shop... brake line bleeding Spridgets 2
W Problems!! Brake line bleeding and leaks Spridgets 5
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
Basil Brake Bleeding Wish me luck Jaguar 10
O Jaguar ABS Brake Bleeding Jaguar 1
Basil Bleeding an XKE Brake System Jaguar 6
WALTER Later model brake bleeding Spridgets 17
Nelson Brake bleeding Spridgets 22
glemon MGB MGB Brake Bleeding MG 14
tahoe healey brake bleeding Austin Healey 7
tahoe healey brake bleeding sequence Austin Healey 2
Monark192 Brake Bleeding Question MG 22
Michael Oritt Bleeding dual master cylinder brake system Austin Healey 6
D Brake Bleeding Triumph 2
MadRiver Brake bleeding problems Triumph 10
MadRiver Brake bleeding advice Triumph 12
A Brake bleeding [say that three times fast] MG 6
S Brake Bleeding Problem!? Triumph 6
tr6web TR6 Brake MC and bleeding TR6 Triumph 7
George Zeck Brake Bleeding ?? Spridgets 15
L Brake Bleeding MG 2
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
