Later model brake bleeding
WALTER
Today was a great day. I drove my Spite for the first time after owning it for 5 years. I bought it in pieces missing many parts. Very exiting! I really appreciate all the great advice I've received from you all over the years. Thank you.
My current problem is the brakes. I upgraded to the split system. It leaked at the brake failure plug so I ordered a new one. The one I received was the wrong shape so I replaced it with a bolt temporarily. Could that be why it is so difficult to bleed? If the piston is designed to block off the side that has failed could it be sliding back and forth without the switch in it. And doesn't bleeding simulate a blown out cylinder?
Thanks,
Walter
jhorton3
Walter-congrats on getting the car back on the road! I know how you feel getting it back together from pieces. How are you going about bleeding the system? Are you getting fluid out where you're bleeding? I usually start with the most far away wheel from the master cylinder in terms of brake line distance.
jlaird
Yes, longest to shortest.
Like right rear, left rear, left front, right front.
WALTER
WALTER
Standard longest to shortest. But I wonder if not having the switch in place may be allowing the piston in the 5-way splitter to slid around causing trouble.
Walter
JPSmit
shouldn't - as long as it isn't threaded deeper than the switch. when I bled mine, after a long time, it took longer than I thought and was harder than I thought. (in part I suspect because the only part I didn't clean out thorougly was the splitter.
That being said, one thing that me hugely was bleeding the brake to the splitter first. In other words, we disconnected the lines at the splitter (one at a time) - pushed till the fluid came through then reconnected that line and pushed the fluid the rest of the way through.
BTW I used DOT 5 so it wasn't as much a worry if it dripped. The paint is still intact.
WALTER
WALTER
To quarts and still no good. It's making me crazier! I guess I should have bench bled the master. Didn't realize it was that important. I've tried both ways of bleeding. There is a bubble hiding somewhere. Arg.
w
JPSmit
what are you using at the end of the bleeding nipple? Lots here use speedbleeders etc. My friend made me a jar with tubing that fit over the nipple so that when the fluid came out -if anything got sucked back in it was fluid not air. then (2 person job) push - hold/ push-hold. Also, make sure your emergency brake is off - don't ask me how I know.
if you have pushed 2 quarts through, you either have a leak or you are letting air back in somehow. If you had a blockage it wouldn't let you use that much fluid. The system takes more fluid than you would think but I don't think 2 quarts
WALTER
WALTER
The e-brake may have been on. I have standard nipples(well my brakes do). I did wrap the threads with teflon tape the last go around. Is it possible with too much pumping on the Mityvac it could suck air through the rear cylinders? If there was a leak it should leak fluid when under pressure.
w
JPSmit
are you using a Mityvac? - if so, I hope others will wade in as I haven't used one.
but I could imagine you sucking air in because the system is not that complicated.
forgive me assuming but when we did mine,
we filled the reservoir and pushed till fluid came out of each end of the splitter (one at a time because it seemed too slow there)
with the lines hooked up, my friend went to each wheel in turn with a box end wrench and his hose apparatus. He put the box end on the nut (on the nipple) and then the hose from the end of the nipple to the bottle.
I pushed the brake pedal as he opened the nipple and as I held the brake down he closed the nipple so that when I let go it drew fluid into the system. we just repeated till the brakes got hard.
I can't imagine what else it could be than air because you are right it would leak under pressure or if it were a blockage it wouldn't flow at all
keep us posted
WALTER
WALTER
"I pushed the brake pedal as he opened the nipple and as I held the brake down he closed the nipple so that when I let go it drew fluid into the system. we just repeated till the brakes got hard"
That's how I expected it to go. Giving it another shot today. Using the above method and mityvac method.
Thanks
Walter
Billm
My opinion (you know how that goes...) is that you are causing the shuttle to move as you are bleeding, and this might be messing you up. The shuttle moves from the high pressure side to the low pressure side and whichever side you are bleeding is the low pressure side so the shuttle could be shutting you off as you try to bleed and it doesn't "spring-return" at all if I recall correctly.
The only option is to verify that the shuttle is centered and then either bleed it VERY slowly with extremely low peddle pressure OR use something like a "mini-vac" bleeder (very low pressure differential) and do it that way.
Good luck
Bill
WALTER
WALTER
Bill, I think your opinion is a good one. I read in one of my manuals that the shuttle can be centered by having someone monitor the brake failure light while bleeding. Working it back and forth slowly till the light stays off. I have to get the proper switch before I can do that. I've gotten to the point of not being able to push the peddle to the floor. I think I was pulling air through the rear cylinders. If I am pulling brake fluid with a strong vacuum through a nipple it would cause the shuttle to close down causing more restriction making it easer to pull air through a seal. Even the one on the other side of the car. That could be a draw back of the Mityvac (no pun intended) on this situation. I think there may be light at the end of the tunnel.
Walter
JPSmit
how's it going?
WALTER
WALTER
I suppose it's going nowhere till I get the switch that will help hold the shuttle in place and center it. Thanks for the help. I'll keep you posted.
Walter
Walter
Walter,
the switch will not hold the shuttle in place in the PWDA (pressure warning differential assembly)..or something like that. The springs inside the assembly will do that. the switch is a normally closed type and when installed will be held open by the shuttle. If something happens to the front or rear system the shuttle will move to the low pressure side, when the pedal is depressed and the switch will drop into a groove turned into the shuttle and activate the warning light.
Definitely bench bleed the master. At this point you most likely have fluid in the system and should not have to worry about the PWDA. If you like take the bolt out and use a mirror to look in the hole and be sure it looks symmetrical. You should be able to see the shuttle. there are o-rings on the shuttle that prevent leakage from one side to the other or into the switch cavity. If you have fluid in the switch cavity it is time to replace the o-rings.
the mity-vac should work, but all the connections must be tight or you will just draw a mix of air and fluid, and get no where. Once you have drawn fluid thru the system, i like to usually go to the old pump and open the bleeder routine.
i hope i havent been to redundant in my description. good Luck
mark
WALTER
WALTER
Hi Mark,
So what I hear you saying is that I need new O-rings instead of a new switch. Now for the big question. Do you know what size O-rings, so I can minimize the brake fluid dribbling in my freshly painted engine compartment? And, How does one remove the shuffle. I'm hoping you don't say hydraulic pleasure.
Thanks,
Walter
If you have brake fluid in the switch cavity then the o-rings are leaking. the PWDA is easily rebuilt. there is a cap on the forward end that unscrews. place the assembly in a soft jawed vice and get a wrench on the endcap. you should be able to easily get the shuttle out. take care not to damage the bore. Is your brass or steel? Steel ones can corrode, brass ones are probaly better, but either way you don't want to have to buy a new one. basically there is the shuttle, and a spring on either end. the shuttle has 4 o-rings IIRC.
when i did mine i bought a bag of the o-rings, 50 i think, i will happily send you some if you pm me your addy.
mark
WALTER
WALTER
Thanks Mark. I'm surprised you got o-rings to work. I actually found a diagram in the Haynes manual. It shows special seals on each end and says the copper washer should be renewed. Moss does have a repair kit for the Sprite failure switch (181-995).I think I'll just order it. My switch is brass so I'm thinking the cylinder should be good.
Walter
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
B BE vs. Later Model Gas tanks Spridgets 2
Scotsman GT6 GT6 early vs later model differences / upgrades Triumph 13
19_again later model turn signal in a 67B MG 2
healeyboz attention later model sprite owners Spridgets 12
G MGB-GT Mileage with a later model MGB GT MG 6
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
drooartz MGB Early tail lights on later car MG 17
D GT6 9 months later. GT6+ progress Triumph 3
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
A Later drum backing plates - hub not clearing Spridgets 2
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
I Wanted emergency brake rods from later Spridget Spridgets Classified 0
drooartz MGB Swapping to dual SU on later MGB with brake booster MG 7
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
M MGB Early MGB engine compatible with later transmission MG 2
dklawson GT6 Float Height, 150CD [Early CD, Not Later CDSE or CD2SE] Triumph 7
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
a40bob Seven years later Other British Cars 13
S TR4/4A exhaust manifold gasket also later tr3 Triumph 2
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
Rut later brake rods on a Bugeye Spridgets 7
T TR2/3/3A For sale: New side curtains, white, for later tr3a Triumph 8
bugedd 1100 or more miles later..... Spridgets 4
B 72 & Later Fuel Tank Spridgets 6
drooartz Later fuel tank in a Bugeye Spridgets 11
D Spitfire One-piece dash for later Spits? Triumph 0
B Later Carbs for Bugeye Spridgets 3
Boink 16 Bugeyes and about 5 later Sprites at the ABFM Portland Spridgets 9
richberman 2.5 years later... Austin Healey 30
Boggsy64 MGB Made it 2200miles and 22 quarts of oil later! MG 7
T later 3000 steering box question Austin Healey 9
T Windshield Stanchion and "plate" on TS60001 and later Triumph 5
BoyRacer How to convert BN1 to later transmission Austin Healey 4
V Early BN4 top vs. Later BN4 top,... Austin Healey 2
HealeyRick Guy Recovers Stolen Healey - 40 Yrs Later! Austin Healey 12
trrdster2000 Insults 32 years later Triumph 3
B TR2/3/3A Swap early TR3A rotors/calipers for later? Triumph 3
F BN2 versus later seats Austin Healey 6
BobMunch A couple Questions about later Midget heater cores Spridgets 0
CZ_Dave Lambrogini Winner Wrecks Car 6 hours later Other Cars 0
Branson later spridget pedal box install in early spridget Spridgets 21
Jer snow in the forecast for later this week... Spridgets 11
Westfield_XI Three broken spiders later..... Spridgets 54
T Difference between 1969-74 and later exhausts Triumph 7
Nelson 39 years later Spridgets 15
