Wrong bleeping coast again
Billm
JP
I'll be GLAD to pick it up for you!
Oh- do I need to give it to you too?
BillM
RickB
I talked to people who saw it in person and it did not get glowing reviews.
One who was at the Portland Oregon ABFM said:
It pulled in and was smoking up front, when the owner was told he said something like "Oh I forgot to turn on the fan again".
It was also leaking fluid and had a flat tire.
He had a for sale sign up but had no interest after two hours when he left, driving off with a flat and coolant leaking out.
V
vagt6
If it sounds to good to be true . . . probably is.
A botched conversion job is one of the worst nightmares to fix, I've found.
This *could* be one of them . . . :nonono:
Dug
I did see it up at the ABFM, it was so "fugly" you didn't want to be caught by anyone you know, looking at it.
It was a right mess.
Dug
lram59 TR4/4A What's wrong with this picture? Triumph 4
B TR4/4A What did I do wrong? Triumph 19
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
S TR2/3/3A I've been wrong for 60+ years: it looks like it's NOT a 1959 Triumph 8
SD Bugeye What is wrong with people Spotted 4
K TR2/3/3A What's wrong at The Roadster Factory? Triumph 5
D Which part is wrong... Spridgets 9
B All the coolant in the wrong place Spridgets 17
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
Jim_Gruber So what did I do wrong here with Bugsy. Spridgets 2
CJD TR2/3/3A Wrong OD Relay? Triumph 16
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
TomMull Off Topic BAT: I know this is in the wrong category but It's following the BAT discussion here. Triumph 6
TomMull TR2/3/3A Wrong SU jet? Triumph 0
P Coolant level indicator wrong? Jaguar 4
KVH TR4/4A Wrong Threads on New Fuel Pump? Triumph 13
B TR2/3/3A I think I've got the wrong seats. Now what? Triumph 13
L TR5/TR250 Brake bleeding….what am I doing wrong? Triumph 4
K TR2/3/3A Clutch Operating Shaft with bolt hole in wrong location? Triumph 3
TRMark What could possible go wrong? Restoration & Tools 4
DanLewis Wrong dipstick? Spridgets 37
M TR2/3/3A Indiactor light wiring. Is this what I'm doing wrong? Triumph 7
catfood Whats wrong with this BN1 Austin Healey 14
C TR2/3/3A Wrong slave cylinder Triumph 3
A What's wrong with my TR4a? Triumph 6
RickB I was wrong. Again. Not ignition switch! Spridgets 16
M TR2/3/3A TR3 slave cylinder, What I'm I doing wrong Triumph 2
tinman58 TR2/3/3A somthing's wrong. Triumph 10
DNK Wedge What's wrong with this Pic? Triumph 12
Jim_Newman Where did I go wrong? Austin Healey 37
SMGoose Wrong Clutch Disc? Triumph 2
Hap Waldrop wrong forum, opps, Spridgets 1
R First timer posting in wrong section.. Spridgets 2
M Cutch Slave Cylinder what am I doing wrong [pics] Triumph 6
T Torque steer from the wrong end of the car Triumph 7
T pistons wrong way round Austin Healey 22
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
I Bare metal respary going horribly wrong Austin Healey 8
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
T T-Series MG TF Notchy Steering - What is wrong? MG 4
J Cost for front suspension refurb right/wrong? Spridgets 8
Got_All_4 TR2/3/3A What's wrong with this brake fluid? TR3 Triumph 19
swift6 Correct me if I am wrong... Please... TVR 20
texas_bugeye oops stack on the wrong end Spridgets 5
TR6oldtimer TR6 What's wrong with this carb '73 TR6 Triumph 7
A sloppy shifter !! somthing must be wrong Triumph 7
G I bought the wrong oil pump Spridgets 5
UmmYeahOk I dont know if this is really cool or really wrong Triumph 18
S wrong fueling Restoration & Tools 5
D Wedge TR7 Parts f/s what am I doing wrong? Triumph 7
