CJD
Alright... I may have made (another) Ebay feaux peaux.
Several years ago I bought an "Overdrive Relay" off Ebay. The issue is the wiring diagram for the OD shows terminals C1 and C2. This relay has terminals C2 and C3, with no C1. I figured this was just a difference in labeling, but then I started trying to find an internal diagram for the relay.
I now believe that a relay with C1 and C2 terminals would be normally open...which is what you need for our Overdrive circuit. BUT, a relay with only C2 and C3 would be a normally CLOSED relay...that would leave the OD engaged until you flip the switch, and then it would disengage.
So, can anyone confirm...is a C2/C3 relay opposite, and unusable?
