Coolant level indicator wrong?
Pete
Member
Daimler Double Six 6.0 L
I'm getting a coolant level warning light, but the header tank is full.
( Warning ! new to Jags, bonnet opening is for grease monkeys ) :wink-new:
Any thoughts appreciated.
Deleted member 8987
hmm. Can you access the radiator proper? COLD, check that level to make sure your recovery system functions and that some sensor in the rad tank isn't giving you an actual proper warning.
Sensors can be floats (in recovery) but usually probe sensors, and no real fixing most of them.
Check the rad first.
Geo Hahn
Probe sensors can corrode and give false negatives. If it is a simple resistance probe you may be able to revive it with some CLR & a toothbrush.
Deleted member 8987
Yeah..well...BTDT, and finally gave up as there was no way. I believe the last one I did had a failed circuit board attached (not this make and model).
P
Pete
Member
My first thought was some thought of blockage, I've decided to put in for a full service and have it sorted out at the same time.
Thnx
Update:
Turns out the sensor had come out, and something to do with a bracket. All sorted :smile:
K TR2/3/3A Radiator coolant level? Triumph 5
bluemiata90 Wedge TR8 COOLANT LEVEL SENSOR LOCATION Triumph 4
N MGB 1978 MGB Coolant Level Checking MG 3
S Spitfire Cyl head coolant hose fitting Triumph 1
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
Govtslug TR6 Coolant Temp Q Triumph 4
T TR2/3/3A TR3 coolant hoses Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
D TR2/3/3A Coolant tap on TR3 block Triumph 3
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
B All the coolant in the wrong place Spridgets 17
G TR4/4A Thoughts on my coolant Triumph 12
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
JFS Wedge Low Coolant Light Triumph 7
Boink Waterless Coolant - thread from the AH forum Spridgets 18
PatGalvin TR2/3/3A Coolant System Hoses Slipping Triumph 5
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
Jim_Gruber Replacing Spridget Coolant Spridgets 21
T TR4/4A Coolant in the oil - again. Triumph 18
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
sparkydave Coolant hoses Spridgets 5
T TR4/4A Oh crud - coolant in the oil Triumph 33
W Waterless Coolant Austin Healey 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
RAC68 Waterless Coolant Austin Healey 29
B TR2/3/3A coolant expelled Triumph 14
Keith_M 1275 burning coolant Spridgets 20
S Coolant Loss Spridgets 32
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
M oil in coolant Austin Healey 16
M TR4/4A Coolant. Triumph 7
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
Keoke Waterless Coolant Austin Healey 12
S TR6 waterless coolant Triumph 6
