TR2/3/3A location of the coolant drains on a tr3a
woodeye3
I'd like to drain and replace the collant on my 1960 tr3a as it overheated this past summer and I added only water. I'm wondering where the drains are located on the block and the radiator. What is the best way to be sure I've gotten all the old coolant out. Thanks
CJD
Lower right side and rear of the radiator... and low on the block below the rear carb, but just above the starter. Unless you drain it regularly, the engine tap will likely be clogged.
STeve 1958
I remember, as a kid, opening up the drains and then putting a garden hose in the filler cap. Made a good seal and blew all kinds of junk out of the system. Don't know if that's the right way to do it but it worked for a 16 year old.
TR3driver
Great Pumpkin - R.I.P
My concern would be blowing the heater core apart. They aren't the strongest construction to begin with, and get weaker with age and rust.
Varies a lot, but its not unusual to find over 100 psi in a garden hose.
I don't run a heater, but if I did, I would close the valve on the head, and disconnect the return on the other side while pressure flushing the engine.
Like John said, the block drain is often blocked. Some digging around with a length of heavy wire will usually open them up.
glemon
Mine was so bad on my old TR4a that a wire would do it, I turned a small drill bit by hand to dig out the crud, and finally got it to drain.
bluemiata90 Wedge TR8 COOLANT LEVEL SENSOR LOCATION Triumph 4
BugEyeBear GT6 GT6 Coolant Block Drain Plug Location? Triumph 4
Stewart MGB Coolant temp sending location 75 MGB MG 3
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
Gliderman8 Members by location FORUM Navigation Questions 11
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
Walter74 Brake Servo Location Austin Healey 6
B MG Fuse Location Spridgets 2
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
6 E-Type brake light pressure switch location Jaguar 5
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
T TR2/3/3A Clutch Pushrod hole location Triumph 4
R TR2/3/3A Throttle rod spring location Triumph 3
J TR6 seat track location on new pans without holes for seats Triumph 2
J TR6 75 TR 6 seat track location Triumph 11
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
Gliderman8 TR6 Inertia switch location Triumph 9
Marvin Gruber BJ7 tach cable location. Austin Healey 3
D TR2/3/3A Side screen location. Triumph 28
T Location of ground wire for BJ8 Austin Healey 6
Gliderman8 TR6 Inertia switch mounting location Triumph 4
G BN6 Battery location Austin Healey 7
RAC68 Top Frame platform location measurements Austin Healey 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
L TR2/3/3A Brake light switch location Triumph 9
B TR6 Winshield washer bottle location Triumph 2
Griz Wing Mirror Location Austin Healey 31
C TR6 72 TR6 Commision Plate and location? Triumph 2
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
HighAltitudeTR3 TR2/3/3A OD Relay location Triumph 3
warwick-steve BT7 soft top frame location Austin Healey 6
Darwin Spitfire Exhaust hanger location Triumph 4
DrEntropy MGB Heater decal location? MG 5
C Speaker location? Austin Healey 24
Griz Fuel filter location Austin Healey 28
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
steveg Best Fire Extinguisher Location Austin Healey 38
B TR2/3/3A Timing chain cover goop location Triumph 4
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
Joe Reed General Tech Starting a screw in a tight location... MG 9
A 1960 BT7 choke location Austin Healey 8
T TR2/3/3A Location for electric fuel pump? Triumph 21
S Embarrassed to ask: Transmission/Gearbox filler location on BJ8 Austin Healey 14
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
K TR2/3/3A Revington's Rear Spring Location Kit? Triumph 9
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
stretchit2 location of vehicle identification number plates Austin Healey 7
