Joe Reed
Trying to start a Phillips screw in a spot where I can only get one hand...so I can't hold the screw with the other hand... can't start it by hand either...and the screw isn't steel, so a magnet won't help. Here's my 5 minute solution...
Clamped the Phillips screwdriver in the vise - pointy end up. Put a drop of super glue into the + on the screw. Put the screw in place on the driver. Came back 5 minutes later and installed the screw with no problem. The super glue held it tight to the driver, but pulled off easily once the screw was tight.
