Fuel filter location
Griz
OK guys, I've decided that my BJ7 needs a fuel filter. I understand that most people install them back by the fuel pump. Question is should it be on the suction or the discharge side of the pump, or does it make any difference? Anyone have a recommendation for a filter available from NAPA or O'Reilly?
Griz
Legal Bill
On suction side you will filter the gas before it hits the pump, which is a good thing. But if car has a steel pipe leading from the tank to the pump you will have to cut the pipe, which some folks do not like doing. I have heard some folks claim that the filter on the suction side can cause the pump to damage itself if the filter gets clogged, but I have never seen that happen myself. If you put it on the pressure side, I see no reason to locate it under the car unless you are trying to hide it. I'd locate it somewhere under the hood where you can reach it easily for replacement and inspection.
Griz
Griz
Thanks for the response LB. I do want to keep it out of sight and I think it would be easier to reach, if need be, by removing the passenger side rear wheel than by locating it deep in the bowels of the engine bay.
Griz
RestoreThemAll
I put mine next to the carbs. The amazon pic looks slightly different than what arrived.
Keoke
ME too:
I also used a clear filter so I can monitor the fuel passing through it and the filter's dirt build up.
Used this set up for years no problems..
Griz
Griz
Bob, because it's a fresh restoration, and even though I had the gas tank professionally checked out and cleaned I still seem to be getting grit in the float bowls.
Dale, that sure looks like a tiny filter. Is it more like a strainer than a filter? I just got back from O'Reillys and got a metal filter (thought it would be more durable than a plastic filter if mounted in the back and exposed to rocks etc) that is about 2" in diameter and about 2" long.
Griz
RestoreThemAll
If I remember correctly the one that I used has a bronze 40 micron filter. The engine ran for many years with no filter. I'd think that particles smaller that 40 microns would pass right on through and out the tail pipe.
RestoreThemAll
The diameter is 1 1/8th inch and about 1 1/2 inch long...and it looks pretty to.:cool-new:
RAC68
Hi Griz,
As Legal Bill indicated, the metal pipe connecting the tank and fuel pump is used to provide the ground for the sending unit. Cutting the pipe will sever the ground and would require another to be installed for the gas gauge to perform properly.
An SU fuel pump uses fuel flow for cooling and a blocked fuel filter will cause it to overheat and fail. According to Dave Dubois (recognized SU fuel pump expert), the SU pump will be able to pass rocks and small birds without issue so tank debris should not cause a problem. However, In this case I would go with John and install the filter on the outlet side of an SU pump.
Use of a modern aftermarket pump is another story. In this case, and if you don't mind installing a new ground wire, installing the filter before the pump and after the fuel tank will provide the greatest protection against the penetration of dirt and debris into the fuel system.
I guess I have been lucky and depended, without issue, upon the original protection provided by the installed screens that are part of the SU pump and carburetors for protection in my Healey.
Hope this helps,
Ray(64BJ8P1)
Healey Nut
Billet filters on both my cars right at the carbs , easy to clean and very accessible.....
But oh the humanity its not "correct"
... An SU fuel pump uses fuel flow for cooling and a blocked fuel filter will cause it to overheat and fail ...
I don't believe that's the case (but I'm open to correction; esp. by DD). The only part of an SU pump subject to heating--from electric current--is the pump body; i.e. the solenoid. If fuel gets in there you have a potentially serious problem, esp. with a points-driven system (fuel + air + spark = problem). The only heating of an SU pump is from the current flowing through the pump body (solenoid), which is only momentary and proportional to the rapidity of the pumping. If the line is blocked--or when the engine isn't running--the pump only fires a few times a minute, and there is no 'hold open' time--like in an OD solenoid--that would cause the solenoid to heat up. If there's an output or intake leak the pump will pump rapidly, which can cause heat buildup in the pump body.
Griz
Griz
Ray, good comment on the grounding of the sending unit, however I had previously installed a separate ground wire for the sending unit so cutting the pump suction line will be no problem. On my car there is more room to add the filter on that side of the pump so that's were it will be. Good comments all...thanks.
Griz
RAC68
Hi Bob,
I am glad you are open to the concept.
Take a look at Dave's document and you will see how the SU pumps will overheat and burn out if fuel is blocked. It is not the temperature of the gas but stopping the operation of the pump that causes the unit to overheat. The pump must be allowed to pump and a blocked input filter would cause it to stop with power on.
https://userwebs.donobi.net/sufuelpumps/Fuel_Pumps/SU_Fuel_Pumps_Facts_and_Myths.pdf
Enjoy,
Ray(64BJ8P1)
Hi Bob,
Enjoy,
Ray(64BJ8P1)
Ray,
Right you are, the pump will 'stall' on the intake cycle and overheat/burn resistor if the inlet side is blocked. For some reason--you didn't specify--I thought you were referring to blockage on the outlet side--where Dave 'recommends' (sort of) to put the filter--which is not a problem. On the output cycle as the points (or SS circuit) will be open and current will not be flowing (the pump will slowly bleed down, allowing plenty of time for the solenoid to cool).
I don't think Dave is a fan of filters in general, esp. as a 'bandaid:'
"The bottom line here is that if you are having a sediment and/or rust problem with the fuel tank that is severe enough to require a filter, then the tank should be removed, cleaned and sealed, or a new tank installed." - DD
If you're sure the tank is clean, it's time to look at the lines.
I don't believe SU pumps are cooled by fuel; the only part that gets warm is the pump body/solenoid--which is insulated by by both a gasket and the diaphragm--from the pump head, which is the only part of the pump that contacts fuel. According to Dave's doc, pumps fail when blocked on the inlet causing current to flow continuously through the solenoid, which causes the internal resistor to fail (not from lack of cooling from fuel flow).
re: "I guess I have been lucky and depended, without issue, upon the original protection provided by the installed screens that are part of the SU pump and carburetors for protection in my Healey."
I agree. Almost 140K miles on my BJ8 without any problem with debris in fuel.
Deleted member 19315
Most su pumps I've had apart already have a filter in the inlet side . It's a cylindrical very fine mesh item. .
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
TonyPanchot 1997 XJ6 Fuel Filter Location Jaguar 1
Dudly 2 part question: fuel filter location, Oil filter. Triumph 5
G fuel filter location MG 43
D General TR Fuel filter before the pump. Triumph 2
HighAltitudeTR3 TR2/3/3A Fuel bubbling at glass filter bowl Triumph 4
G General TR Fuel Filter Question Triumph 4
D TR4/4A TR4A clogged fuel filter Triumph 13
I Bigeye fuel filter and placement recommendation? Spridgets 8
O MGB 1975 MGB No Fuel to the filter MG 2
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
sundown TR6 glass fuel filter Triumph 11
K TR2/3/3A 5/16 inline fuel filter? Triumph 2
John_Mc Fuel filter replacement Triumph 6
P Inline Fuel Filter Austin Healey 10
DNK Fuel Filter Triumph 17
nevets fuel filter type? Austin Healey 3
glemon Fuel Filter Placement Triumph 13
tahoe healey fuel filter Austin Healey 1
rggav MGB 65 MGB fuel filter MG 3
SkinnedKnuckles Purolator Fuel Filter Alert, I guess. Triumph 5
nevets Fuel filter type? Austin Healey 3
SkinnedKnuckles Fuel Filter Triumph 1
R Fuel Filter & Pump MG 2
pjsmetana Fuel Filter, anyone got a part # for this thing? Triumph 11
F BJ8 Fuel Filter Installation Austin Healey 14
M Fuel Filter Sizes? Which is best Triumph 9
Creatrixx Fuel Filter Question British Motor Corp 3
T Fuel filter Triumph 13
Shinsen774 Fuel Filter Change Interval MG 2
T TR2/3/3A Fuel filter madness on the TR3 [holy cow] Triumph 11
DNK Fuel Filter Triumph 5
RSMTR8 Wedge TR8 Fuel Filter Triumph 0
SCguy Wedge TR8 fuel filter Triumph 1
A Fuel filter Austin Healey 2
A filter for fuel pump-your thoughts Austin Healey 10
BoneIdle Idle Speed Drops After Fuel Filter Element Change MG 1
6 Fuel Filter installation Austin Healey 14
RedTR3 TR2/3/3A TR3 Fuel Filter Triumph 6
TheAssociate Spitfire Spitfire Fuel Filter Triumph 21
RedTR3 TR2/3/3A Fuel Filter TR3 Triumph 2
Baz I've lost a fuel filter.... Spridgets 12
T MG 101 - What size fuel filter MG 2
Atrus Air in fuel filter Spridgets 11
jerrybny Fuel Filter Level Triumph 8
F S3 E-type Fuel Filter Jaguar 1
AUSMHLY fuel filter Austin Healey 21
prb51 TR2/3/3A Tr3 fuel filter Triumph 3
G Re-routing fuel filter Triumph 2
Obtong Fuel Filter Question MG 11
