filter for fuel pump-your thoughts
Andy65
Is anyone putting a fuel filter between the gas tank and the fuel pump? I seem to remember doing this 20 years ago to prevent crud from the tank getting into the pump. I have a filter by the carbs.
GregW
Platinum
Hi Andy,
I have my filter between the tank and pump. I'd venture a guess that 75% put it in the engine compartment for ease of checking and changing.
bighly
Between tank and pump. Cheepo plastic (VW) type. Do not use glass ones under the car :smile:
Michael Oritt
I mount the filter between the tank and pump in all my cars--I think it is easier to check and clean if necessary an inline filter than the filter built into an SU and safer to have this connection in a place where it will not dump onto a hot exhaust header, etc.
ArtQ
Member
I have mine in line in the engine compartment just before the first carb. Easy to get at. Used one made for a Triumph from Moss
Keoke
I locate mine in the engine compartment too. It is a billet machined Russel filter with a sintered bronze element which is firmly attached to the shroud brace just ahead of the front carb.--Fwiw--Keoke
57_100_6
Member
I use two, a filter between tank and pump and regulator/filter between the pump and carbs. Could be a little overkill but I can usually tell if the fuel is flowing.
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
nevets
Mine's in the engine compartment too...easy to check. Not sure if the pump cares if the fuel is filtered? maybe it's better?
Dave Russell
Yoda - R.I.P
Same filter, same location for me.
healeyneil said:
I use a facet pump and their literature very clearly spells out the need for a filter before the pump.
healeyneil, i also installed a "facet" mine has a built in filter. good pump but a bit loud so i installed it as the backup. /bcforum/images/%%GRAEMLIN_URL%%/savewave.gif
D General TR Fuel filter before the pump. Triumph 2
R Fuel Filter & Pump MG 2
HighAltitudeTR3 TR2/3/3A Fuel bubbling at glass filter bowl Triumph 4
G General TR Fuel Filter Question Triumph 4
D TR4/4A TR4A clogged fuel filter Triumph 13
Griz Fuel filter location Austin Healey 28
I Bigeye fuel filter and placement recommendation? Spridgets 8
O MGB 1975 MGB No Fuel to the filter MG 2
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
sundown TR6 glass fuel filter Triumph 11
K TR2/3/3A 5/16 inline fuel filter? Triumph 2
John_Mc Fuel filter replacement Triumph 6
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
P Inline Fuel Filter Austin Healey 10
DNK Fuel Filter Triumph 17
nevets fuel filter type? Austin Healey 3
glemon Fuel Filter Placement Triumph 13
tahoe healey fuel filter Austin Healey 1
rggav MGB 65 MGB fuel filter MG 3
SkinnedKnuckles Purolator Fuel Filter Alert, I guess. Triumph 5
nevets Fuel filter type? Austin Healey 3
SkinnedKnuckles Fuel Filter Triumph 1
pjsmetana Fuel Filter, anyone got a part # for this thing? Triumph 11
TonyPanchot 1997 XJ6 Fuel Filter Location Jaguar 1
Dudly 2 part question: fuel filter location, Oil filter. Triumph 5
F BJ8 Fuel Filter Installation Austin Healey 14
M Fuel Filter Sizes? Which is best Triumph 9
Creatrixx Fuel Filter Question British Motor Corp 3
T Fuel filter Triumph 13
Shinsen774 Fuel Filter Change Interval MG 2
T TR2/3/3A Fuel filter madness on the TR3 [holy cow] Triumph 11
DNK Fuel Filter Triumph 5
RSMTR8 Wedge TR8 Fuel Filter Triumph 0
SCguy Wedge TR8 fuel filter Triumph 1
A Fuel filter Austin Healey 2
BoneIdle Idle Speed Drops After Fuel Filter Element Change MG 1
6 Fuel Filter installation Austin Healey 14
RedTR3 TR2/3/3A TR3 Fuel Filter Triumph 6
TheAssociate Spitfire Spitfire Fuel Filter Triumph 21
RedTR3 TR2/3/3A Fuel Filter TR3 Triumph 2
Baz I've lost a fuel filter.... Spridgets 12
T MG 101 - What size fuel filter MG 2
Atrus Air in fuel filter Spridgets 11
jerrybny Fuel Filter Level Triumph 8
F S3 E-type Fuel Filter Jaguar 1
G fuel filter location MG 43
AUSMHLY fuel filter Austin Healey 21
prb51 TR2/3/3A Tr3 fuel filter Triumph 3
G Re-routing fuel filter Triumph 2
Obtong Fuel Filter Question MG 11
