Which part is wrong...
David_Doan
I put together the flywheel, clutch, trans today. It seems that the slave push-rod is about 0.7" too short. I verified that the push-rod is the correct length for a 948 with smoothcase (2.75"), also the same as previous. The release bearing is new and the same dimensions as the old one. The clutch and pressure plate are the same parts I took off. The slave cylinder is the 7/8" bore. The clutch did not work well before the tear-down, I guess this is why. It would catch as soon as the petal came off the floor.
So which part is wrong? or should I just procure or fabricate a longer pushrod?
Some pics to help:
Is that a smooth case transmission?
David_Doan
Yes, I think everything is correct, just maybe need a longer pushrod. I can’t find a spec for how much tolerance there should be. It seems that it is subjective depending on what peddle height you want the clutch to engage.
I'm thinking your slave cylinder will not be compressed that far when connected to your MC.
David_Doan
I think you’re correct, hence no spec. It looks like that if I did increase the pushrod length by about .7” then the slave cyclinder could over run the travel of the fork and bend it.
Hopefully now that the previously very worn pushrod and fork bushing have been replaced the clutch will work better than before.
apbos
David
I think Trevor is correct, it has been a few years since I installed mine on my smooth case. When you charge the system the rod will be more forward. I would also notch the upper bolt hole of the slave, so you can more easily remove and install it when it is in the car.
Regards
Paul
Jim_Gruber
A ote I saved many, many years ago. This may already be on Gerard's Website.
Per Frank C. 1275slave rod is 2-11/16" from the center of the hole to the end.
1275 it should measure 3" from the center of the hole to the end of thepushrod. The 948 and 1098 cars are only 2 1/2" long
K TR2/3/3A Mystery TR Part Triumph 9
I MGB Help! What is this part for? MG 13
R Part Identification Austin Healey 5
Agrandshort TR2/3/3A Unknown part panel Triumph 5
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
J TR2/3/3A Part Identification Triumph 7
CARSINC Unknown Part Spridgets 5
equiprx Mystery part Other British Cars 2
R TR6 Help: Brake Part Source or …. ? Triumph 1
N MGB Electrical Part Identification MG 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
R Cool Remanufactured Part for Vixen 2500 TVR 7
N MGB Name that part MG 5
D TR2/3/3A Another mystery part(s) Triumph 2
P Wanted Part # BHA5138 Triumph Classifieds 0
AngliaGT MGB Dumb Question - What's This Part? MG 3
D TR2/3/3A Another mystery part Triumph 8
B Useful Part or Boat Anchor? Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
B TR2/3/3A Hard Top Part Triumph 2
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
BritBob TR2/3/3A Part restored TR3A in Oregon Triumph 0
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
Healey Nut Mystery Part Austin Healey 2
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
vping T-Series Looking for TD Part # MG 3
D TR2/3/3A Another mystery part..or two Triumph 14
T Trying to identify a steel plate part Austin Healey 2
Bayless Missing important part Spridgets 0
H TR2/3/3A Rimmerbros Part Triumph 7
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
Lin TR6 Do you know this part? Triumph 6
Lin Name this part - I am stumped! Austin Healey 24
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
tr6nitjulius General TR Part 3 What We Missin' Triumph 0
tr6nitjulius General TR What we missin' part 2 Triumph 0
T Wedge TR7 engine, need help identifying part. Triumph 5
tr6nitjulius General TR What We Missin' Part 1 Triumph 0
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
B MGA Mystery MGA chassis part MG 3
Sarastro TR4/4A What's the purpose of this door part? Triumph 9
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
NutmegCT Thanks button - part 2 FORUM Navigation Questions 8
steveg Searching Burlen's website for part numbers Austin Healey 0
K What is this broken part in my transmission/OD? Austin Healey 6
