Positive Ground History with Triumph Motorcycles
ctp
I have gotten an almost complete set of Triumph Pre Unit Motorcycle Technical Service Bullitens from 1951 - 1959. Very interesting reading - I think. Anyway TSB #93,June 23 1952 explains why Positive Ground was decided upon. Check it out here in my Virtual VinMoto Garage (CP's)in the TSB folder!
https://www.vinmoto.org/gallery/v/VinMoto-Garage/CO-OHVinMoto-Garages/
racingenglishcars
Quite interesting reading.
They mentioned a Lucas "Energy Transfer Ignition System" in #257. I hope it would be better than the original on my '57 T20 as it was garbage (along with the generator and oil pump).
The T20 has a permanent magnet generator. Kind of removes the need for a regulator.
I really wonder about the engineering of the day. The TSB-002 actually tells people to put oil into a drinking container (coca cola bottle) and that the bottom of the writing is about 130cc.
And there we have it. If we change ground from negative to positive, would it not just move the corrosion to the other side?
B Positive-Ground LED Light Strip Austin Healey 8
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
M 66 ā€˜ BJ 8 Positive ground identification Austin Healey 4
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
R TR2/3/3A Positive-ground LED lights Triumph 13
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
M TR2/3/3A Positive or negative ground? Triumph 6
P Jump starting a positive ground BJ8 Austin Healey 4
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Question about positive vs negative ground Spridgets 13
K TR2/3/3A Converting to Positive Ground....... Triumph 1
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
M LED lamps for Austin Healey with positive ground Austin Healey 0
Lukens What's the down side of "positive ground system"? Triumph 8
P How to use timing light with positive ground? Austin Healey 14
R 66 midget tach positive ground Spridgets 2
Mowgli81 Positive Ground Disconnect in Trunk Austin Healey 4
E Positive ground or Negative ground. What have you? Austin Healey 12
Geo Hahn Brakelight Flasher for Positive Ground Triumph 2
cbrvfr Running modern accessories with positive ground? Austin Healey 4
S positive and negative ground Triumph 7
BOBBYR Positive ground dwell Austin Healey 23
T Why positive ground? Austin Healey 17
S Size 34 Optima Battery w/positive ground Austin Healey 33
M Jump start positive ground car Austin Healey 10
I Bugeye-better to have negative or positive ground? Spridgets 17
JohnnyMead Relays for Positive Ground Triumph 6
D Positive or Neg ground, should I switch? Austin Healey 51
newmexTR3 positive/negative ground coil question Triumph 14
TR4 Pertronix - Positive Ground Triumph 4
livinginthepast Positive ground tach/dwell meter hook up Spridgets 1
Newkie Converting Positive ground to Negative ground MG 4
19_again flamethrower coil on positive ground B MG 4
Magyar How to convert from positive to negative ground? Spridgets 10
Sarastro An option for a radio in a positive-ground car Spridgets 6
66healey Positive to negative ground conversion Austin Healey 2
jvandyke positive to negative ground conversion Spridgets 11
J Positive Ground Radio- Other British Cars 1
athenssprite positive to negative ground Spridgets 4
F Pertronix Positive Ground Question Austin Healey 9
