Positive to negative ground conversion
66healey
Member
I have just finished converting my car from positive to negative ground, and now my tach doesn't work! I followed the instructions listed on Hendrix wire wheels web site, and everything else seems fine. I believe that I blew a diode in the tach, as the instructions have you reverse the power connections to the unit and what was originaly the ground connection has a diode connected to it. Any one else had this problem with this conversion? If so, any idea of the part number for the diode?
thanks
66healey
66healey
Member
Oops, never mind. You must be smarter than what you are working on! I assembled the loop on the back of thr tach correctly and every thing works!
GregW
Glad I could help....Oh, wait, I didn't. :blush:
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
M TR2/3/3A Positive or negative ground? Triumph 6
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Question about positive vs negative ground Spridgets 13
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
E Positive ground or Negative ground. What have you? Austin Healey 12
S positive and negative ground Triumph 7
I Bugeye-better to have negative or positive ground? Spridgets 17
newmexTR3 positive/negative ground coil question Triumph 14
Newkie Converting Positive ground to Negative ground MG 4
Magyar How to convert from positive to negative ground? Spridgets 10
jvandyke positive to negative ground conversion Spridgets 11
athenssprite positive to negative ground Spridgets 4
mine Positive convert to negative ground? Triumph 15
S positive and negative ground MG 59
Michael Oritt Battery Jumping Negative/Positive ground cars Austin Healey 31
Ohiobugeye Positive Ground to Negative Ground? Spridgets 12
T ground negative, positive Spridgets 6
R Positive to Negative Ground Issue Austin Healey 6
Y Positive Vs Negative ground + Alternator Vs Generator Austin Healey 1
R Positive to Negative Ground Conversion BJ8 Austin Healey 3
M positive to negative ground Austin Healey 3
P Positive to Negative Conversion Austin Healey 1
P TR4/4A Positive/Negative Earth Dilemma TR4A Triumph 11
C Positive or Negative Earth Triumph 15
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
memphis Positive to Negative Conversion Austin Healey 2
T TR4/4A TR4a positive or negative earth? Triumph 17
M Positive to Negative Conversion Spridgets 3
B Positive-Ground LED Light Strip Austin Healey 8
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M 66 ā€˜ BJ 8 Positive ground identification Austin Healey 4
R TR2/3/3A Positive-ground LED lights Triumph 13
Sopwith_Camel positive camber xj Jaguar 0
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
P Jump starting a positive ground BJ8 Austin Healey 4
K TR2/3/3A Converting to Positive Ground....... Triumph 1
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
DanLewis Correcting positive camber in a Bugeye Spridgets 21
M LED lamps for Austin Healey with positive ground Austin Healey 0
