Question about positive vs negative ground
M
Member 10617
Since I am new to positive ground cars, I need to make sure I understand:
I know that to remove a battery on on a negative ground car, detach and remove the negative cable first and then detach and remove the positive cable. To replace the battery, attach and tighten the positive cable first, and then attach and tighten the negative cable.
On a positive ground car, I assume that the procedure is reversed. Am I right?
dklawson
That is correct.
It's easy to remember if you focus only on removing and re-attaching the cable connected to the car body first.
SaxMan
What was the thought process in having a positive-ground system? It seems counter-intuitive.
Pythias
In the beginning.... . they (automobiles) were all positive ground. I believe it had to do with the direction of the flow of electrons, which actually move from the negative (more free electrons) to the positive.. It's been said (anecdotal evidence) that the batteries are less likely to lose their charge in a positively grounded car when its just sitting... I haven't converted mine to neg ground and I haven't needed a battery for ... WOW, not that I think about it.. I bought this battery before I move into this house, over 16 years ago. During the winter months (the rainy season in Washington state runs from late October till March) I try to drive it once a month and it's always held it's charge.
Roger
Bronze
In the very beginning they were negative ground. Positive ground appeared in the thirties to preserve batteries.
JPSmit
Interesting responses - I just naturally assumed that because they were British - of course they would be counter intuitive!
M
Member 10617
Many thanks. There are some very interesting articles on the Internet about the pros and cons of positive grounding. Seems that not only do batteries last longer, but positive grounding apparently is less destructive of the old plastic coating on wires (?) and other benefits.
My car came with positive ground, and I will keep it. But with positive ground, I cannot install or plug in any modern devices or they will be destroyed.
nomad
Wow, I was aware of the battery issue but didn't realize it was that dramatic! Bill L are you sure you didn't forget at least one!
LexTR3, just a matter of wiring up a separate outlet or isolating metal bits. I'm going to put a GPS charger in my 65 that is still +.
Kurt.
Pythias
Go to Radio Shack and get a fully insulated one. Tuck it up under the dash when not in use and pull it out to plug stuff (like a Garmin or a cell phone charger) in.
Pythias
So far as I can tell, they changed it because everyone THINKS electricity flows from Positive TO Negative.
dklawson
I don't know how much research went into the article linked below but you may find at least one explanation for positive ground and the change to negative ground in the article linked below.
https://lajagclub.com/the-argument-for-positive-ground/
For additional thought, it was not just British cars that were positive ground. During the days of 6V electrical systems many American cars were also positive ground (but generally not GM) .
Bayless
Doug that article jogged some old memories. That is exactly how it was explained to me many years ago when I first got interested in LBCs and wondered why their electrics were "backwards."
M
Member 10617
Yep.... That is the interesting article I was referring to. Some friends have recommended that I swtch my car to negative ground, but I think I'll leave well enough alone.
newmexTR3 positive/negative ground coil question Triumph 14
S TR2/3/3A Positive Ground Question Triumph 2
F Pertronix Positive Ground Question Austin Healey 9
kurts100 Question on Pertronix for my positive gnd. 100-4 Austin Healey 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
