Positive Ground Alternator wiring.
apbos
I have located a positive ground alternator with a speedo cable end. Should make it easy to boost my amps so I can run a cooling fan etc. So will I need to rewire around my voltage regulator or can it just be wired in straight. I suspect it will need to be rewired as it will be supplied with DC current, but just checking. Anyone have some instructions for wiring through a dummy voltage regulator. Trying to go with the stock look on the car.
Regards
Paul
dklawson
See this:
https://www.minimania.com/Changing_from_Dynamo_to_Alternator_721
The article above explains how to convert the regulator box to be a junction box so you don't have to cut the wiring harness. I would double check the info in the link to what others tell you as the article above is also aimed at negative ground installations.
You said you found a positive ground tach drive alternator. I knew that there were a few positive ground alternators. I had no idea there were ever positive ground versions with tach drive. Take good care of it.
Joe Schlosser
Bugeye guy has these in both pos and neg ground. Neg ground is $10 cheaper.
dklawson
I am glad that the price on the alternator in a generator housing has come down in price. When I first saw these about 10 years ago they were only available in Europe and cost about $800. I still didn't know a tach drive version was available. Let us know what you think of it.
apbos
apbos
Joe. Thanks for the heads up. Looks like they make a dummy junction box, so that answers part of my question about wiring. I think I might have an old box in the garage and will see if I can use it. Doug I will order after the weekend and let you all know how it works.
Thanks
Paul
nomad
Paul, apparently your BE doesn't have stock instruments????
If not why do you need a tach drive gen?? And no speedo is polarity dependent unless its a modern GPS version.
Kurt
apbos
apbos
Kurt
I have the stock instruments, but a few additional period (Speedwell and Stevenson) rally instruments on the shelf and a radio ( which was installed on the car,, that I have removed) thus I had planned on keeping it positive ground. The original tach needs a cable in the bugeye. My latest fear is that my relatively new Moss Wiring harness (Yellow generator wire) may not be rated for the 45 amps coming from the replacement alternator? Thoughts.
Regards
Paul
nomad
Kurt
Regards
Paul
I see, Paul.
If your alternator is internally regulated and I'm sure it is I think you could just run a heavier wire directly to your battery in parallel with the stock wire. Might not look exactly kosher.
Kurt
nomad
On a BE you could run it to the start solenoid [switch]. Probably be able to hide it quite easily that way.
Kurt
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
Y Positive Vs Negative ground + Alternator Vs Generator Austin Healey 1
B Positive-Ground LED Light Strip Austin Healey 8
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
6 Relay wiring positive ground Spridgets 4
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
M 66 ‘ BJ 8 Positive ground identification Austin Healey 4
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
R TR2/3/3A Positive-ground LED lights Triumph 13
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
M TR2/3/3A Positive or negative ground? Triumph 6
P Jump starting a positive ground BJ8 Austin Healey 4
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Question about positive vs negative ground Spridgets 13
K TR2/3/3A Converting to Positive Ground....... Triumph 1
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
M LED lamps for Austin Healey with positive ground Austin Healey 0
Lukens What's the down side of "positive ground system"? Triumph 8
P How to use timing light with positive ground? Austin Healey 14
R 66 midget tach positive ground Spridgets 2
Mowgli81 Positive Ground Disconnect in Trunk Austin Healey 4
E Positive ground or Negative ground. What have you? Austin Healey 12
C Positive Ground History with Triumph Motorcycles British Motorbikes 1
Geo Hahn Brakelight Flasher for Positive Ground Triumph 2
cbrvfr Running modern accessories with positive ground? Austin Healey 4
S positive and negative ground Triumph 7
BOBBYR Positive ground dwell Austin Healey 23
T Why positive ground? Austin Healey 17
S Size 34 Optima Battery w/positive ground Austin Healey 33
M Jump start positive ground car Austin Healey 10
I Bugeye-better to have negative or positive ground? Spridgets 17
JohnnyMead Relays for Positive Ground Triumph 6
D Positive or Neg ground, should I switch? Austin Healey 51
newmexTR3 positive/negative ground coil question Triumph 14
TR4 Pertronix - Positive Ground Triumph 4
livinginthepast Positive ground tach/dwell meter hook up Spridgets 1
Newkie Converting Positive ground to Negative ground MG 4
19_again flamethrower coil on positive ground B MG 4
Magyar How to convert from positive to negative ground? Spridgets 10
Sarastro An option for a radio in a positive-ground car Spridgets 6
66healey Positive to negative ground conversion Austin Healey 2
jvandyke positive to negative ground conversion Spridgets 11
J Positive Ground Radio- Other British Cars 1
athenssprite positive to negative ground Spridgets 4
