Jump start positive ground car
AUSMHLY
Others will chime in, so I hope I'm not wrong.
Positive to positive, negative to negative on the batteries.
Don't let the cars body touch each other.
GregW
Platinum
Yep.
I remember something about which terminal is connected last being important but I don't remember what. just don't let a loose clip hit the bumper.
RestoreThemAll
OK, so would one of those battery jumper boxes be a better choice? We have one from Sears and paid I think $20.
Can you push start a Healey safely? I have a BJ7 and recall push starting it several times in the 1970's. That doesn't make it a good idea. Could it hurt the OD?
Usually, you want to connect the ground last--and away from the battery, if possible--in case there's any hydrogen gas around the battery and you get a spark.
Keoke
:savewave:
It would be OK provided the car's battery is not absolutely dead.
:savewave:
Yes if you are on a good hill or have a bit of extra help'
:savewave:
No you should not hurt the OD as it's switch should be disengaged
Fwiw----Keoke
Johnny
Hmm, lets see, you're hooking your neg battery terminal(hot) to a neg battery terminal (grd) in a car, possibly running. I would think you would get a big SPARK!
Unless the donor battery is out of the car (disconnected) I wouldn't do it.
Nope. There is no absolute 'ground' (except maybe for AC like in your house). In fact, the more correct term is 'common,' for the common frame the accessories are 'grounded' to. That's why you don't need a special battery in a positive ground car: just connect the positive terminal to the chassis instead of the negative. I've jump-started neg-'ground' cars with my pos-'ground' BJ8 several times.
If you think about it, since electricity travels in a circuit both terminals are 'hot;' it's just that one terminal is made common so that it's convenient to (electrically) attach things like starters and generators to it (else you'd need two cables to all electrical components and everything would have to be thoroughly insulated). IOW, the chassis is used as part of the 'wiring' of the car.
If you connect neg-pos battery terminals from a negative ground car to a positive ground car and connect the two chassis you're connecting the circuits in series and you'd get 24V across your components (similar to connecting two 6V batteries in series to get 12V). Your starter would spin like crazy ... for a couple seconds. If you connect neg-neg and pos-pos you're making the connection in parallel, which combines the available current from both sources but the potential (voltage) remains the same (12V).
You will sometimes get a little spark when you make a neg-neg or pos-pos connection, which is why you should make the last one to the chassis away from the battery.
why
no different than any other car, push start with ignition on and pop clutch in 2nd or 3rd gear, or just connect like battery terminals to like battery terminals with jumper cables being careful that giant alligators on cables touch nothing other than terminal, donor car running or not running, OD or any other electical on or off, just like a Chevy,
PatGalvin Any Issues with Jump Start of Positive Earth LBC Triumph 9
G MGA MGA Jump Start MG 3
WillR bad jump start MG 26
MattP Won't start and won't jump. MG 19
S TR4/4A Rear jump seat Triumph 6
P Jump starting a positive ground BJ8 Austin Healey 4
waltesefalcon Jump! Lotus 1
W One of y'all need to jump on this! Spridgets 4
W Somebody needs to jump om this... Spridgets 2
T proper jump starting technique Austin Healey 2
L BJ8 Phaze III Jump seat back questions Austin Healey 2
drambuie Pit crews of the 1938 Grand Prix's [Next time i will jump out and refuel myself] Austin Healey 1
Jim_Gruber Here's a new one. I'm going to jump right on this Spridgets 7
Basil Aaaay! Now you can jump the shark! British Motorbikes 1
Lynn Kirkpatrick Battery Booster/Jump Starter Restoration & Tools 9
bthompson Rain makes my tach jump! Spridgets 4
Perrymip TR2/3/3A TR3 Sudden Temp Jump Triumph 7
J Jump Starting Positive Earth cars. Austin Healey 3
lbc_newbie someone better jump on these!! Spridgets 5
Dudly About to jump in, feet first Spridgets 26
W Somebody needs to jump on this one. Spridgets 4
ronzet Speaking of BN4 Jump Seats Austin Healey 2
K New member jump in with cam ??? Triumph 8
D Jump to Panasports? MG 0
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
J Spitfire No start after fiddling with dash Triumph 2
AHSebring How do I create "Contact" to "Start Conversation" in my About Tab? FORUM Navigation Questions 1
O Wedge 79 TR7 no start Triumph 5
J MGB 1966 MGB won't start MG 1
K TR2/3/3A Sluggish cranking on start up? Triumph 5
L T-Series Hard to start MG 11
mctriumph General TR NEVER start a car with stale gas Triumph 0
K TR2/3/3A Timing chain rattle on start up? Triumph 2
KVH General Tech Initial Start Up After Rebuild Triumph 23
B Healey Won't Start - No Spark Austin Healey 38
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
G Pre-War how to start a 55 mgtf. MG 3
KVH TR4/4A Hard Start When Engine Hot Triumph 20
K TR4/4A TR4 no start Triumph 26
M Spridget wont start Spridgets 50
D TR2/3/3A Getting difficult to start. Triumph 6
K TR2/3/3A Motor knocking at start up? Triumph 11
Q TR2/3/3A Where to start?! Triumph 13
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
dougie Bruce McLaren's start in an Austin Healey Austin Healey 0
K TR2/3/3A Hard start questions.... Triumph 4
pairof75's General TR Circulate fluids without engine start Triumph 10
S TR2/3/3A Will Not Start Triumph 52
R TR2/3/3A Re-start after total restoration Triumph 22
S General MG 77 MG no start MG 31
