TR2/3/3A Getting difficult to start.
DavidApp
My TR3A was getting more difficult to start. It seemed to be getting worse despite having fixed the float bowl gasket leak.
Had a look at the choke linkage last night and found that the outer part of the cable had slipped through the clamp making the choke totally ineffective. Had to add a piece of packing around the outer to get it to clamp and we are back in business.
May have to look for a clamp on collar if it slips again.
David
sp53
Glad you found it. Around here with the rain and cold, the choke is often a problem when they start starting hard. Yes that little area where the clamp fits and the amount of outer cable sticking past the clamp and the amount of inner cable that sticks out past the outer cable that attaches to the arm is a real science/ART. Plus the length of the lower rod that moves both chokes choke is a sub-science. AND moreover then the whole choke needs to return and shut off, often a pain.
I still do not have mine the way I like on this new project. The front carb was running rich, but I believe a cam lob was gone so that might be my problem for the richness that I could not figure out.
steve
DavidApp
Something like this may be the answer to the slipping problem.
David
Frank Canale
I will throw this out there, to make a simple soft shoe like for a vice. It could be aluminum or copper to conform and grip the outer part of the choke cable but not deform it. Only a suggestion, good luck. Frank
Platinum
I've kept a loose collection of brass shim stock of various thicknesses in the toolbox for just such issues.
DavidApp
I am thinking of making a bicycle brake type thimble/sleeve to fit on the end of the cable to prevent the outer sliding trough the clamp.
What I fid is working so far.
David
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
R TR2/3/3A Tr2 getting it back on the road Triumph 30
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
M Getting the wishbone with bushings back onto the frame... Spridgets 2
V Getting ready for Spring Austin Healey 6
Healey Nut This is just getting freaky !!! Austin Healey 21
Jim_Gruber So what is your LBC getting for Christmas Spridgets 39
