gbtr6
I rebuilt my TR's engine last year. It has a Goodparts S-2 cam, .060 Pistons, higher compression, and I run 2x SU HS 6's. It has been run in but just. The problem is it has no power. The timing at 1,000 rpm is 12 degrees advanced. The carbs have not be redone. I suspect them as when I was brining it out of storage and at one point it started to act normal, good zip. Then, a dog again.
I am no good at diagnostics, unfortunately. I am thinking of removing the carbs and disassembling them and cleaning them thouroughly.
What at does everyone else do in this situation after a rebuild in order to get it back running well again?
Thanks,
Perry
Thanks,
Perry
