TR2/3/3A Identifying positive or negative ground....
M_Pied_Lourd
Hi guys,
Looking at a TR3A with no battery installed and trying to identify if the car has been converted to negative ground. Is there a quick way to do this?
Cheers
Tush
Brinkerhoff
The neg. cable end is smaller and won't fit the positive terminal on the battery without opening it up. So check that first. The CB terminal on the coil is the wire that attaches to the distributor ( contact breaker) on a positive ground car. SW is from the switch. If the coils been changed out the positive terminal would go to the distributor,if its still a positive ground system. If its been changed to negative ground then the neg. terminal on the coil wire would go to the distributor.
Geo Hahn
Of course you could just ignore what has gone before and 'convert' it to whatever polarity you want. Worst case is that it is already converted and nothing happens.
Of course you'll want to be aware of any polarity sensitive devices that have been added (e.g. a radio) and not offer them the wrong polarity.
TR3driver
Great Pumpkin - R.I.P
It's also entirely possible that someone hooked the battery up negative ground and didn't bother to switch the wires on the coil.
As Geo said, hook it up the way you want and go with it. Probably best to repolarize the generator as well, since you have some doubt and it certainly won't hurt to do it.
I don't think I've ever seen a TR3 that managed to keep it's original "helmet" cable ends since new. Has anyone else?
trrdster2000
On some of the early radios there was a plug on the back to change polarity, so you can check yours. Not a lot of people knew about this and threw away the originals.
Wayne
M_Pied_Lourd
M_Pied_Lourd
Fantastic guys! Thanks for all the responses. It is appreciated.
Cheers
Tush
HerronScott
Doesn't the ammeter need to have the cabling reversed if you switch polarity unless you don't mind it reading discharging when charging and vice versa?
I don't think my TR3 has the original helmet battery cables but one of my TR4A's does. Screws are MIA though.
Scott
TR3driver
Scott
Wow, I didn't even realize they were still using them that late!
Yeah, ammeter leads should be swapped, but like the coil, not everyone does.
glemon
Geo, you beat me to it. My 67 BGT had them too, a bunch of them since it had two six volt batteries.
I remember when I reversed the polarity on my 4a and the ammeter read backwards until I figured out you can just switch out the two big wires going in on the back.
This could be another clue on the car in question provided the prior owner swapped it out when ( and if) they switched polarity.
Don Elliott
Dave - You say you were looking at this TR3. Does this mean you have bought a third TR3A - to go with your parts car and your TR6?
Cheers
Don
M_Pied_Lourd
M_Pied_Lourd
Cheers
Don
Hi Don, yes I am afraid so :glee: I now own TS44836LO, a 59 3A
Cheers
Tush
toysrrus
Hi Folks,
I was at the "Eurofest BMW Classic Car Show" last Sat. in Greer, SC (Great Show as usual). Over 400 cars there & only "European" marques.
There was an "Original, Un-Molested, Un-Restored" `58TR3 there with the "Helmet" cable ends in reasonably good cond.
Its too bad they did`nt have a "Preservation" class cause he would have won!!
Regards, Russ
thechileman
Lol, I know this is hijacking the thread, but when I got my TR4, it had the "helmet" battery cables. I didn't even consider they might be of interest to someone. I think I pitched them. I replaced them with conventional cables when I switched it over to negative ground. I will look again in my junk box, and if they are still there I will post up and offer them to somebody no charge. I need to learn that when I think something is junk, I need to ask here first.
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
V Help with identifying morris eight Other British Cars 12
T Lotus 7 - help identifying parts Lotus 5
P TR6 identifying switch Triumph 3
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
J MGB Need help identifying these parts MG 6
T Wedge TR7 engine, need help identifying part. Triumph 5
P Identifying a Ring and Pinion Austin Healey 8
S Identifying 12G940 heads Spridgets 4
JimLaney HELP: Identifying Chasiss and Engines Spridgets 7
Desert Rat Help identifying a hardtop Spridgets 10
P TR2/3/3A Need Help Identifying These Seats Triumph 6
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
T Identifying vintage of a Weber DCOE Spridgets 4
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
L Request help with identifying this AH 1960 3000 part. Austin Healey 1
jfarris TR2/3/3A Identifying a TR4 A Overdrive Triumph 5
AngliaGT Wedge Help Identifying TR7/8 Parts Triumph 8
S help with identifying fiberglass frontend Spridgets 27
J Need help identifying Lucas parts Other British Cars 10
CZ_Dave Help in Identifying this British Ford? Other Cars 11
J help identifying my transmission... Triumph 8
B Please help identifying top bows MG 5
J Identifying Lotus 907 engine castings [Jensen H] Other British Cars 8
S Need help identifying rims Other British Cars 11
angelfj1 TR2/3/3A TR3A help identifying part Triumph 6
angelfj1 TR2/3/3A TR3A - help identifying part Triumph 9
Morris Help identifying carb set... Spridgets 18
T BugEye - identifying rear axles[?] Spridgets 0
C help identifying hard top Spridgets 1
Gliderman8 TR6 Help with identifying my TR6 heads Triumph 3
angelfj1 TR2/3/3A Help identifying part [TR3A] Triumph 5
T Identifying year of production from serial number Spridgets 5
vping Need help Identifying an OD Transmission MG 3
A Help needed - identifying cylinder head castings Austin Healey 0
Monark192 Help identifying Carbs MG 2
vping Help identifying this odd part MG 11
T Need Help Identifying Parts MG 5
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
S New member with a Q about identifying an engine. Other British Cars 0
S Greetings! and help identifying this engine?. Sunbeam (Rootes) 14
Mickey Richaud Help with Identifying this TR Triumph 6
ChrisS MGB Identifying a MGB Transmission MG 1
T Help identifying part Spridgets 16
MGTF1250Dave Help Identifying Distributor Triumph 3
B Positive-Ground LED Light Strip Austin Healey 8
P Positive to Negative Conversion Austin Healey 1
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
