I got a complete Jensen Healey engine/transmission plus, heads, cam boxes, block, crank, intake manifold, aluminum flywheel, cam covers, a transmission, a bell housing, a gear box casting (no gears), and three oil pans. I got these parts from a friend who is cleaning out his shed and wanted to get rid of the parts. I want to use these parts to build an engine but first I need to find out what I have. For example, the oil pans, two of them look very similar with a square deep sump. One has a smooth cast bottom. The other has a finned bottom. The third pan is very shallow with the sump being less than two inches deep. They all have a casting number and I recognized the first three digits as 907 on one of the pans.
How do I identify these parts as to whether they came from a Jensen Healey or a Lotus? Is there a good manual I can use to build/rebuild the engines?
Thanks
Jorge
Thanks
Jorge
