Identifying 12G940 heads
Smilin' Ric
I am researching the large valve 1275 head, casting number 12G940. I have found there are 3, 4, or 5 variations of this head, with one (two?) having a larger intake valve, and maybe some improvement in the ports. My main question is how to ID the desired large valve head without removing it to measure the valves. Is there some mark or other telltale sign?
Cheers,
Ric
'60 Bugeye
SD Bugeye
My 12G295 head has a casting on the top side of the head this ids the layout of the part.
are you saying that your 12g940 could have different sized valves?
that is the way I thought you woukd ID it
that seems odd
S
Smilin' Ric
that seems odd
Yep. Confusing, eh?
12G9401 5/16"1 5/32"21,4cc1275GT,A/M1300Can be modified to the specifications below
9 Bolts33,3mm29,53mm Sprite MK IV, Marina 1,3
12G9401 13/32"1 5/32"21,4ccAustin 1300 GTFits on 1275 Gt when bigger valves are needed
11 Bolts
35,6mm MG 1300 MK II, late Cooper S
AEG165
1 13/32"1 7/32"21,4ccCooper S Can be used instead of the 11 bolted 12G940
12A185 12A185 was early casting coded yellow AEG165 is later colour coded brown or blue
12G9401 5/16"1 5/32"21,4ccTurbo MGSodium cooled exh. Vlaves & improved cooling but thinner deck
I am looking for some very smart person to tell me some magical way to tell which one is which, without pulling the head off to put eyes on the valve heads.
Cheers,
Ric
dklawson
Sorry, I'm not smart enough to give you definitive information. However, I did search for a while.
From the Mk1 Mini Forum:
https://mk1-forum.net/viewtopic.php?f=3&t=4902&p=34140&hilit=12g940+heads#p34140
The numbers after the casting mark are in inches/mm for the intake... then exhaust.
Only one of the later 12G940s in the list below mentions special marks/stamps. I think for most you need to measure the valve diameters. Threads I found while searching suggest there were at least 7 or 8 different raw castings for the 12G940.
My Mini was built with the AEG163 head but like many of those castings the valves had sunk into the head. Though my car's head was not cracked, in general they are prone to cracking between the inlets and exhausts. I replaced my car's head with a large valve 12G940 and have been happy. However, I didn't know about the physical appearance differences. The head I bought was from an A+ engine so the head is not perfectly flat around the thermostat area (see the text below the list below).
"[FONT=&quot]AEG163 1.401"/35.6 1.22"/31.0 21.4 Later Mk1 & Mk2 Cooper S[/FONT]
[FONT=&quot]12G940[/FONT][FONT=&quot]* 1.312"/33.33 1.15"/29.2 21.4 1275GT, Austin 1300, all late A+ models inc. Turbo but not MG Metro[/FONT]
[FONT=&quot]12G940[/FONT][FONT=&quot] 1.401"/35.6 1.15"/29.2 21.4 [/FONT]
[FONT=&quot]Stamped '12G1805' on flat area by thermostat - MG1300, 1300GT & Mk3 Cooper S[/FONT]
[FONT=&quot]12G940[/FONT][FONT=&quot]* 1.401"/35.6 1.15"/29.2 21.4 As above plus MG Metro[/FONT]
[FONT=&quot]*Note:[/FONT]
[FONT=&quot]A+ head castings - despite having the same [/FONT][FONT=&quot]12G940[/FONT][FONT=&quot] casting number - are considerably different in appearance, loosing the flat area behind the thermostat housing and around the rest of the rocker/head stud areas to a sculptured look - where these areas are replaced by a 'sunken' cast finish. [/FONT]
[FONT=&quot]The A+ castings were introduced with the appearance of the Metro in 1980, although some late 1275GTs (1979-on) had them fitted. Generally they are easily recognised by their colour - a putrid yellow on the small-bore castings and bright red on the large-bore ones, a paint finish that is VERY difficult to remove, even in a chemical tank.[/FONT]
[FONT=&quot]The MG Metro Turbo shares the same valve sizes with the other non-'big valve' [/FONT][FONT=&quot]12G940[/FONT][FONT=&quot] variants but has 8mm, sodium-filled exhaust valves.[/FONT]
[FONT=&quot]A+ [/FONT][FONT=&quot]heads[/FONT]
[FONT=&quot] generally have three collet grooves in the valves, collets are 14-degree cone taper instead of the 10-degree on single groove collets (so parts are not interchangeable between single and triple groove types) and the top-caps have a raised ridge around the collet hole."
[/FONT]
S
Smilin' Ric
"AEG163 1.401"/35.6 1.22"/31.0 21.4 Later Mk1 & Mk2 Cooper S
12G940* 1.312"/33.33 1.15"/29.2 21.4 1275GT, Austin 1300, all late A+ models inc. Turbo but not MG Metro
12G940 1.401"/35.6 1.15"/29.2 21.4
12G940* 1.401"/35.6 1.15"/29.2 21.4 As above plus MG Metro
*Note:
A+ head castings - despite having the same 12G940 casting number - are considerably different in appearance, loosing the flat area behind the thermostat housing and around the rest of the rocker/head stud areas to a sculptured look - where these areas are replaced by a 'sunken' cast finish.
The MG Metro Turbo shares the same valve sizes with the other non-'big valve' 12G940 variants but has 8mm, sodium-filled exhaust valves.
A+ heads
Thanks Doug.
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
V Help with identifying morris eight Other British Cars 12
T Lotus 7 - help identifying parts Lotus 5
P TR6 identifying switch Triumph 3
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
J MGB Need help identifying these parts MG 6
T Wedge TR7 engine, need help identifying part. Triumph 5
P Identifying a Ring and Pinion Austin Healey 8
JimLaney HELP: Identifying Chasiss and Engines Spridgets 7
Desert Rat Help identifying a hardtop Spridgets 10
P TR2/3/3A Need Help Identifying These Seats Triumph 6
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
T Identifying vintage of a Weber DCOE Spridgets 4
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
L Request help with identifying this AH 1960 3000 part. Austin Healey 1
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
jfarris TR2/3/3A Identifying a TR4 A Overdrive Triumph 5
AngliaGT Wedge Help Identifying TR7/8 Parts Triumph 8
S help with identifying fiberglass frontend Spridgets 27
J Need help identifying Lucas parts Other British Cars 10
CZ_Dave Help in Identifying this British Ford? Other Cars 11
J help identifying my transmission... Triumph 8
B Please help identifying top bows MG 5
J Identifying Lotus 907 engine castings [Jensen H] Other British Cars 8
S Need help identifying rims Other British Cars 11
angelfj1 TR2/3/3A TR3A help identifying part Triumph 6
angelfj1 TR2/3/3A TR3A - help identifying part Triumph 9
Morris Help identifying carb set... Spridgets 18
T BugEye - identifying rear axles[?] Spridgets 0
C help identifying hard top Spridgets 1
Gliderman8 TR6 Help with identifying my TR6 heads Triumph 3
angelfj1 TR2/3/3A Help identifying part [TR3A] Triumph 5
T Identifying year of production from serial number Spridgets 5
vping Need help Identifying an OD Transmission MG 3
A Help needed - identifying cylinder head castings Austin Healey 0
Monark192 Help identifying Carbs MG 2
vping Help identifying this odd part MG 11
T Need Help Identifying Parts MG 5
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
S New member with a Q about identifying an engine. Other British Cars 0
S Greetings! and help identifying this engine?. Sunbeam (Rootes) 14
Mickey Richaud Help with Identifying this TR Triumph 6
ChrisS MGB Identifying a MGB Transmission MG 1
T Help identifying part Spridgets 16
MGTF1250Dave Help Identifying Distributor Triumph 3
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
R New cylinder heads Austin Healey 18
A Identify Heads Austin Healey 1
