memphis
Hi All!
I have a really dumb question....
In reading the conversion steps of changing our cars from positive common (ground) to negative, once you flip the battery connections, things like the fuel pump only require you to also flip their wires around. Sounds easy...
So my question is, with the car setup as positive common (ground), why cant we just flip things (modern devices) like radios and cig lighter wires around and use them this way? Why do those devices need a power converter to run on a positive ground setup? Very puzzling for me...
Thanks for your comments.
Bob
Bob
