Horn/Headlight Relays
Bill_Reid
Where might I be able to obtain horn and headlight relays for my '60 Sprite?
Boink
Bronze
drooartz
Local auto parts store should have some generic relays for you. Bugeyes never had any relays, so you can go with whatever will work.
Jim_Gruber
Google: Parts Express - The sell the 5 pin Bosch Type Relays and Relay Sockets along with a nice handout for wiring headlight relays. Nice folks located between Dayton and Cincinnati. They also sell Heat Shrink Tubing in all colors by 3 foot pieces along with heavy duty inline fuse holders and fuses. I always stock up ok goodies when I get by there.
There is a nice place to install the relays right where the harness splits on the PS of the car and you can mount the relays to the clutch/brake pedal cover plate. You can pull out the I think if IIRC the Blue /White and Blue/Red wires right there along with the ground wire. I ran a fused power wire tie wrapped to the harness up and around and used a large lug to tie to the always on power stud on the solenoid. Again be sure and fuse it. The headlights draw a lot of current. I've be happy to provide pics if needed.
A huge difference in headlight brightness. I upgraded to halogen beams and Bugsy can find his way through the darkest nights. Higher current draw vs. standard can't see 10 feet in front of me at night standard headlamps. This is one upgrade that may not be exactly period correct/concours correct is definitely a safety factor to consider. And the placement really does not look out of place. Go for it.
smaceng
Bill, I installed extra fuses and relays under the dash of my BE to help cure the prince of darkness evils. If you are interested let me know and I can email you the information.
Scott in CA
B
Bill_Reid
Jim, I would appreciate pics if not too much trouble.
Scott, I am also interested in your method of wiring extra fuses and relays.
Thanks all....
Sarastro
Jim_Gruber
Steve, you've obviously looked at this for a long, long time. One of the issues I have with Bugsy my '68 Sprite is if undriven for 4-6 weeks battery is not sufficient to crank him over and get started. The only thing that should be drawing power is the keep alive for the radio memory. Is this enough load to drain a battety in 4-6 weeks. Now battery is 2-3 years old but I would think there should be enough power in the battery to support only the keep alive circuit. I should pull the keep alive off of the + solenoid terminal and measure to see if there is any other current draw. I'm just about 100% certain and that keep alive wire is fused just in case. I am running halogen headlights with relays, XM, and AM/FM CD player with a generator. It may be load is such that the battery really takes a dive running those short errands at night to the grocery store and never really gets recharged. A short session on the battery charger takes care of the issue and I'm sure if Bugsy was driven with more regularity the issue would go away. Your thoughts on other than upgrading to an alternator which is on the "roundtoit" list.
Jim_Gruber
Oh and I will try to post a pictire of my headlight relay install this weekend. Again on the "roundtoit" list.
Bayless
Jim, several years ago I bought Battery Tenders for everything that does not get driven regularly. I have not had any battery problems since. Well worth the investment.
Sarastro
Jim, the keep-alive for the radio really shouldn't kill a well charged battery in any length of time. A battery has a certain amount of "self discharge"--that is, it just loses charge sitting around, and of course if it doesn't get completely charged up, the situation will be worse. I suspect that's all that's going on. When my cars sit around a long time, I put them on the charger for a while. A battery tender probably is a good idea, too, although I haven't ever used one.
RickB
Jim, "6 weeks" - really???
I can't imagine mine going without driving half that long.
:chuncky:
F Spitfire 77 Spitfire Horn/Headlight Stalk Conflict Triumph 4
P TR6 Horn issue 1974 TR6 Triumph 5
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
Jim_Gruber Intermittent Horn Spridgets 2
Joe_Healey TR5/TR250 Bubba Horn Triumph 0
G TR4/4A Horn Brush Question Triumph 7
edkap2002 TR6 horn brush Triumph 3
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
Jim_Gruber In need of a really loud horn Spridgets 13
T Lucas HF 1748 horn parts Austin Healey 5
S TR4/4A Horn relay Triumph 2
F TR2/3/3A Horn/Directional Assembly Triumph 2
