Horn relay
RickF
The relay was only used if the optional dual horn setup was installed. Most Bugeyes were equipped with only one horn and have no relay. If I remember correctly the relay used with the dual horn setup was fastened to the right side inner fender.
R
rossco
Rick. Thanks for the pic. I have the dual horns. I'll go into the catacombs and see if I have one lying around. R
Sopwith_Camel horn relay wiring Jaguar 3
P TR6 TR6 Horn Relay Problems Triumph 8
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
S TR4/4A Horn relay Triumph 2
T TR5/TR250 TR6 Horn Relay Triumph 1
Gerry M TR6 Horn Relay Question Triumph 4
S replacement horn relay Triumph 9
mabbott TR6 TR6 horn relay? Triumph 1
KVH Horn Relay Triumph 10
Stinger TR4/4A TR4A Horn Relay Triumph 1
KVH TR4/4A TR4 Horn Relay Triumph 2
B Horn Relay or O/D Relay Triumph 16
Jim_Gruber Horn Relay Spridgets 19
R How to connect a horn relay Austin Healey 2
KVH Horn Relay Switch Triumph 1
S Horn Relay Triumph 4
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
S Indicator / Horn Switch Austin Healey 10
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
