TR2/3/3A Cracked TR3 block...
markctr3
First of all, I would like to thank everybody for your comments. I think this is going to be a GREAT experience! I made a call to a shop in Orlando by the name of Imagination Engineering (407 521-5730). Jeff is the man I spoke with, and I believe he is the owner (he speaks with a British accent...does it get any better than that?). I found out through a friend that he has a block for sale, so I asked him about that engine and asked him a couple of questions about mine. He told me that 9 out of 10 TR3 blocks will have a crack in the "web" between the sides of the block. He said not to worry, since the head actually seals against the liners, and the head studs act as a girdle to compensate for the slight lack of integrity. I have to believe him since his comment resulted in not buying his block.
I'll keep you guys posted as to the progeress of the rebuild. I hope to be back on the road in 6 weeks...just in time for the best cruising weather down here in Florida.
Thanks again for your imput. Like I said this seems like a GREAT forum!
P Cracked windshield Other Cars 0
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
P TR2/3/3A Windshield Cracked Triumph 12
Kleykamp TR2/3/3A Cracked Block??? Triumph 6
D MGB MGB Cracked Cylinder Heads Question MG 4
BoyRacer 6 cyl aluminum head - cracked valveseat Austin Healey 1
TimK 2 cracked windshields Austin Healey 13
aeronca65t Cracked Rostyle Spridgets 6
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
MCNX_BFF Cracked and leaky Triumph 20
M cracked head ??? Triumph 6
Carlos TR4/4A TR4A cracked cylinder head Triumph 8
Stewart cracked head? MG 7
tweety It wasn't a head gasket or anything cracked..... Spridgets 1
tweety I'm assuming head gasket, cracked block or head??? Spridgets 4
eschneider MGB MGB sunvisor rivets [and now cracked glass] MG 4
Baz Cracked coil spring! Spridgets 25
SilentUnicorn 1500 Cracked head? Spridgets 3
B Piston is cracked MG 7
U cracked exhaust manifold Spridgets 19
G TR2/3/3A TR3A cracked frame Triumph 3
J cracked wishbone! Spridgets 17
J New Soft-top, or reupholster cracked window? Triumph 6
G Quarter Light Frames Cracked! MG 0
N TR2/3/3A TR-3A cracked exhaust manifold Triumph 8
M TR6 Help- TR6 rear shock mount cracked Triumph 3
aeronca65t Cracked WIndshield Restoration & Tools 15
