MGB MGB Cracked Cylinder Heads Question
  • Thread starter Deleted member 8566
  • Start date
Deleted member 8566
Hey everyone,
Right now I have a post in the WTB section trying to find a crack free cylinder head. Although something has been recently brought to my attention by two separate people and I wanted to get a confirmation before I made any decisions. I would appreciate any help and advice.
So I have taken 7 cylinder heads to a local machine shop to be checked for cracks. According to the shop, ALL of them are cracked somewhere or another. We all know MGB cylinder heads are prone to cracking and notorious for doing so. However, what I have been told is that at least 1 or 2 of the cracks are surface and not near where the cylinder meets up, the valve seat area or spark plug area, basically just a crack somewhere in the top casting near nothing significant.
I haven't seen the severity of all of them in person, just the initial 2 I dropped off. I am going to pick up the rest in a couple hours.
The shop these heads are at does not do welding repairs to cylinder heads either. Also, they don't specialize in British/European car heads (I'm in San Antonio, almost no one does, not sure if that makes any type of difference)
My questions are first, if the cylinder head has a surface crack near nothing significant, if it still usable (without repair), second, I know one of the heads cannot be repaired for cracks but the other 6 may be able to be repaired by a different shop, and if that is the case, what should those type of repairs cost?
Also is there any other information I need to know?
I know it is hard to give feedback without seeing them and until I go grab them I know it's still a bit of a guessing game, but I do appreciate any help that can be offered.
Best regards,
Justin
bobhustead
I was an MG line mechanic for a couple years after I got out of college in 71, and there are guys on this forum with a lot more knowledge, but, I did not know of a propensity for cracking. Hard to imagine that all these heads are cracked. Go to another machine shop. Bob
I have a stack of cracked MGB heads. Most are cracked ( later heads) on the outside by the #2 sparkplug and head bolt. They weep fluid but could still be run. I've seen several that were welded, some worked some didn't. The early heads seem to crack between valves. Those, I've been told are easier to repair.
Marv
David_DuBois
For crack repair in non critical areas, you can use a process called stitching. Basically you drill and tap a hole at one end or the other of the crack. Screw in a bolt with locktite and then cut the bolt off flush with the surface. You then drill and tap another hole half way in the first bolt and put another bolt in with locktite, cut off flush and continue to the other end of the crack. I had that done on a head with a crack in it and it is still in use. For more information on this process go to: https://www.locknstitch.com/
Cheers,
eschneider MGB MGB sunvisor rivets [and now cracked glass] MG 4
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
JohnGone Wanted Spare & Jack for an '80 MGB MG Classifieds 0
