TR2/3/3A TR-3A cracked exhaust manifold
n2stom
Hi all, looking over my TR-3A eyesterday I noticed the exhaust manifold had a pretty good size crack. Has anybody had success with a weld repair or should I find a replacement? Anyone have one to part with? thanks Tom
Geo Hahn
Looks like you're not getting anyone who has tried this so I'll pass along a comment from a respected source that was on the archives of another forum...
Manifolds are tough to properly weld. Here's why:
1) The metal is cast and heating it will make it tend to warp, thus the fit after the weld is iffy.
2) Two different metals (the manifold, and the Welding rod) are hard to get to stick together with any degree of permanence. As the engine warms up the two metals heat up at different rates. This causes one to expand more than the other and try to come apart.
Simon TR4a
I would second Geo's comment; there are new welding sticks for welding cast iron, but I have heard this is a not a reliable solution.
(I am not a welder, so I am passing on second-hand information here.)
You might find a used one or look into a header from Moss or elsewhere.
Simon.
Adrio
If you can't get your fixed, let me know as I may have one in my pile of left over bits. Just email me if you wish.
TR4MAN
Member
Thr trick to welding exh manifolds is to use a nickle welding rod. Any good welder can do this. The thing to do is find something solid you can bolt to. You secure the item and let it cool in place. All that said, I wouldn't think tr3 manifolds are that hard to find and getting a good one is a whole lot easier.
Earl
I have no idea if it will work, but just before you buy a replacement try JB Weld. Let us know if it works.
Good luck
G
Absolutely, JBWeld is a no go. I had the exhaust manifold and the head welded on my TR3 some years ago and they held well. IMHO, it all depends on the skill level of the welder. What have you got to lose?
Bill
N
n2stom
Thanks All. I reckon I'll attempt to find a replacement. The welders available to me don't seem to enthusiastic.
thanks again for the info
tom
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
U cracked exhaust manifold Spridgets 19
P Cracked windshield Other Cars 0
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
P TR2/3/3A Windshield Cracked Triumph 12
Kleykamp TR2/3/3A Cracked Block??? Triumph 6
D MGB MGB Cracked Cylinder Heads Question MG 4
BoyRacer 6 cyl aluminum head - cracked valveseat Austin Healey 1
TimK 2 cracked windshields Austin Healey 13
aeronca65t Cracked Rostyle Spridgets 6
MCNX_BFF Cracked and leaky Triumph 20
M cracked head ??? Triumph 6
Carlos TR4/4A TR4A cracked cylinder head Triumph 8
Stewart cracked head? MG 7
tweety It wasn't a head gasket or anything cracked..... Spridgets 1
tweety I'm assuming head gasket, cracked block or head??? Spridgets 4
eschneider MGB MGB sunvisor rivets [and now cracked glass] MG 4
Baz Cracked coil spring! Spridgets 25
SilentUnicorn 1500 Cracked head? Spridgets 3
B Piston is cracked MG 7
G TR2/3/3A TR3A cracked frame Triumph 3
J cracked wishbone! Spridgets 17
J New Soft-top, or reupholster cracked window? Triumph 6
G Quarter Light Frames Cracked! MG 0
M TR2/3/3A Cracked TR3 block... Triumph 0
M TR6 Help- TR6 rear shock mount cracked Triumph 3
aeronca65t Cracked WIndshield Restoration & Tools 15
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
